Page 18 of 37 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 365
Thread: Auto switch to Guidance screen for iG?
  1. #171
    Jun 2006
    LS,
    I have not tested this yet - just getting to it pal... but? So just the basic RR.ini commands mentioned to load it up, and the ExecTBL data for volume adjust, and that's about it?
    Lovely - let me know if I missed anything else but appreciate everyones awesome work on this one...
    Thx
    Quote Originally Posted by liquid_smoke View Post
    Ok, i have found and fixed the issue with lowering the winamp volume when IG speaks instead of Pause.
    Add to ExecTBL.ini, if IGPAUSE and IGRESUME already exist overwrite those lines.
    Code:
    "IGPAUSE","!PRESET;IG3;WINAMP||SETVOL;WINAMP;180"
    "IGRESUME","PRESET;IG3;WINAMP"
    change the number 180 to whatever volume you want winamp to be set to when IG speaks. You will have to play with this value to get it right depending on how loud your system is inside your car. Since IG also lowers or raises the wav volume when it speaks, you'll have to compensate. 180 is a little over 50% winamp volume.
  2. #172
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    This beta has 3 releases so far. File name follow this format: RoadRunner_auto-iG-mm-ddB.zip
    - 1st dated 10/19. Has no option to pause on voice.
    - 2nd dated 10/20. Add option to pause on voice.
    - 3rd dated 10/24. Add master setting, and more custom commands.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  3. #173
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Talking Progress Check
    Thanks for clearing it up Matrix! I'm waiting for the 10/30 beta that has variables for each item, so buttons can be created in a skin to toggle the options on and off
    I have only the one button, the Auto Switch, that works so far for this plugin "Live", using the only avail variable "autogpssw"
    The "iGidance sound" buttons work, and just move the specified .wav to a temp folder and back to adcivate/deactivate that sound.
    ALL of the buttons right now, save the correct value to the rr.ini file. However, until variables are created for the Pause Music, and Switch screen times, Road Runner has to be reloaded for those changes to take effect.
    Here is a screen capture of what I have put together thus far:
    My Fiero Build Thread
  4. #174
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by JohnWPB View Post
    I have only the one button so far, using the only avail variable "autogpssw"
    All of the buttons right now, save the correct value to the rr.ini file. However, until variables are created for the Pause Music, and Switch screen times, Road Runner has to be reloaded for the changes to take effect.
    Thats a pretty good idea
    beer replenishment fund
    mp3car live search
  5. #175
    Jun 2006
    Guys - if you were using an external player, i.e. PowerDVD ... could MASTER or other be used in the ExecTBL definition... I am going to try this but wanted to ask first. LS - your stuff works perfect here, I just needed to tweak as u mentioned.
    What I want to be careful of is being able to adjust another vol besides WinAmp while not hosing the IG sound in the process - what would be the best VOL to adjust for that guys? ---
  6. #176
    Sep 2006
    Sabattus, ME
    JohnWPB that is hot....i cant wait..
  7. #177
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Works well with what I have so far, just need the variables to be added RR's code to complete it. It makes it nice, as there is no need to manually add anything to the RR.ini, as when a feature is accessed, it will create the entry automatically in the ini with the value selected, so it will be recalled the next time RR is started.
  8. #178
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    You could try something like this for now for your pause button on-off
    “IGPAUSE”,”BYVAR;AUTOPAUSE;<<STOP”
    “IGRESUME”,” BYVAR;AUTOPAUSE;<<PLAY”
    2001 S10 ZR2
    Chucks Skin - to old
  9. #179
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Sonicxtacy02 View Post
    an indicator. From outside rr this would be the code
    SETIND;CUSTOMguidance;ON - turns it on
    SETIND,CUSTOMguidance;OFF - turns it off
    i'll have to peek at the source to figure out how to add it internally
    Sonicx, when do you want the indicator to be set to on? Only when Guidiance screen is on? This indicator has nothing to do with voice right?
    Let me know asap.
  10. #180
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by MatrixPC View Post
    Let me know asap.
    actually in coding i've found the best way to get the most up to date turn is to have the indicator set to ON whenever autogps switches to the gps screen and OFF when it changes back to LASTSCR (regardless of whether its in guidance mode). And here's my progress so far today i have direction indicators working.. albeit in a crude way for the time being. the arrow is pulled directly from the gps skin and can be placed anywhere on any skin. Right now only way it works is if i manually start the exe i compiled but once the mods to your program are complete it will run once each time the indicator is set to ON.
    i plan on also including the data from the four bottom boxes of iG (eta etc etc) as well as autozoom based on speed.
    Lastly, should you not like the look of the standard iG arrows you can use any other .png image stored in your skin file.. so it doesnt HAVE to appear as it does below.
    Anyone know what font iG uses. That would help me move forward
    Live mp3Car Facebook Chat
  1. Replies: 4
    Last Post: 01-26-2006, 03:35 AM
  2. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 03:02 PM
  3. Auto off switch
    By Ill1 in forum General Hardware Discussion
    Last Post: 01-17-2005, 03:50 PM
  4. auto start/shutdown with tower switch
    By HybridFox in forum General Hardware Discussion
    Last Post: 11-07-2004, 12:10 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
