Page 19 of 37 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 365
Thread: Auto switch to Guidance screen for iG?
  1. #181
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Latest release 10/30.
    Change in this release. Read the included readme file for more info.
    - all ini setting for this mod can be change during run time by using SETVAR. (JohnWPB you got it.)
    - Add an indicator IGIND when iG is in Guidance mode, not voice (Sonicxtacy02 let make it works).
    Thanks SangreDeThor for hosting the file.
    Download RoadRunner_auto-iG-10-30B.zip
    Refer to Post #164 by LS for option to use pauseonvoice=true to lower Winamp volume when iG given Voice Direction.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #182
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Thanks Matrix!
    Quote Originally Posted by MatrixPC View Post
    WooHoo! Thanks! I should have the code up and working by tomorrow (Headed out tonight, & can't work on it )
    On another note, I have gotten a couple IM"s and emails, as I am working on the options screen for my skin. Seems people do not know how to set up AutoIG, and where to get the actual last version.
    I just spent some time, and reading through this thread, I can see why!
    Ok, In the first post it mentions:
    And a few lines below that:
    Download: RoadRunner_auto_iG-10-20B.zip is the latest beta release. Earlier release file name is RoadRunner_auto_iG-10-19B.zip. Thanks 65coupei6 for hosting the file.
    In the first post it says to see post #108 for the ini settings, In post #108 it says:
    lastscreenswitchtime is now has more time [5-30] seconds. Anything lower than 5 mean no switch back.
    Also in the first post, it saysL
    Read post #47 for more info for setting in RR.ini.
    Where it says:
    lastscreenswitchtime=[0-10]
    Default is 0. How many seconds for RR to switch to Last screen after Guidance screen disappear or Voice instruction finish. 0 to disable auto switch to Last Screen (You manually hit whatever screen you want or stay in GPS screen). Default is 0 => Stay in GPS screen.
    In the first post there are 3 different links to the file:
    2 links to the 10/24 version
    one link to the 10/20b version
    1 link to the 10/30 version.
    So to set this up correctly, I need to look at the 3 different versions in the main post, and download the latest one. Then then need to go to post #108 for the INI settings, even though in the first post it also says to go to post #47, but those settings are wrong, so the ones from post #108 need to be used, NOT the ones linked to in post #47.
    So honestly, I can see where some could find it a bit confusing on what to get where and how to set it up with the corect commands.
    My Fiero Build Thread
  3. #183
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Working good - thx
    2001 S10 ZR2
    Chucks Skin - to old
  4. #184
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Strange Problem
    Ok, I just tried out the new variables and they are working great!
    I did just run into a very strange problem. The voice and music when I first tried it are reversed! When iG Speaks, the music un-pauses. When iG stops speaking the music then pauses again.
    This is probably something that just got out of sync, but it may be best to try to find a way to error trap that somehow.
    I just went into iG's menu, and then volume. When I press "Test" and the "DESTINATION" speaks, the music starts again, and immediately pauses fairly quickly as it is a short word to speak.
    I then hit the spacebar to make iG repeat the last command, and the music plays quite nicely in the background while she is speaking
    EDIT: Ok, when returning to the main menu, the music again started back up, and it is now "in Sync", not sure whats happening to cause it.
  5. #185
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by Chuck View Post
    Working good - thx
    what is autofull, auto top and auto list ?
    beer replenishment fund
    mp3car live search
  6. #186
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i can see the IGIND indicator but its always off. Doesnt matter if its in guidance mode or just on the gps screen its off. Anyway to turn it on when iguidance speaks? The information i need to pull from the gps screen is always updated when the voice is talking. This could be added to your function that makes rr pause when iG is talking.
    Live mp3Car Facebook Chat
  7. #187
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by liquid_smoke View Post
    Auto gps = standard gps screen with setting.
    Auto full = full screen gps and completely gone on return.
    Auto top = full screen gps and the top shows all the time on return so you can see next turn at all times.
    Auto list = puts the map on the play list in all players
    2001 S10 ZR2
  8. #188
    Woodbridge, VA
    Blog Entries
    55
    hey Chuck, quick question for you.
    is this how the byind works?
    Code:
    "ONSKINSTART","BYIND;IGIND;<<RUN;C:\Program Files\Control\igaddon.exe"
    This should do nothing with the IGIND is off and run that program when its on correct? (your the skin guru so i figure u know)
  9. #189
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by Sonicxtacy02 View Post
    Code:
    Yes it should work but if it does not try this
    "ONSKINSTART","BYIND;IGIND;<<RUNADDON"
    “RUNADDON”,”RUN;C:\Program Files\Control\igaddon.exe”
    2001 S10 ZR2
  10. #190
    Sep 2003
    Beach City, Socal
    I tested it well before release and it works fine. Can you double check the code on skin file?
    The only thing that affect this indicator is the master setting: igautosw which must be set to on to use any feature in this beta.
    Okay a little about my testing. On my skin there is an ONLINE indicator. I just replace the word "ONLINE" with "IGIND". When iG is in Guidance mode, the indicator turn on. To simulate driving, I use iG demo mode.
  1. Replies: 4
    Last Post: 01-26-2006, 03:35 AM
  2. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 03:02 PM
  3. Auto off switch
    By Ill1 in forum General Hardware Discussion
    Last Post: 01-17-2005, 03:50 PM
  4. auto start/shutdown with tower switch
    By HybridFox in forum General Hardware Discussion
    Last Post: 11-07-2004, 12:10 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
