Page 20 of 37 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 365
Thread: Auto switch to Guidance screen for iG?
  1. #191
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i tested it with my flash skin as well as the request sdk example. I'll test it that way too.
    Live mp3Car Facebook Chat
  2. #192
    Woodbridge, VA
    Blog Entries
    55
    i stand corrected the indicator does work.. there must be something wrong with my byind statement.
    but in doing some further testing its probably best if the indicator is turned on when iG is speaking rather than only in guidance mode. Turning it on when ig is speaking means the addon app i'm writing gets the information anytime its changed rather than in guidance mode which only updates at BEST half the time.
    if this is too much trouble by all means lemme know and i'll find a way to check for iG speaking myself
  3. #193
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Sonicxtacy02 View Post
    Do you want it with pauseonvoice and/or gpsonvoice enable/disable.
    In my opinion, indicator is on whenever iG is in Guidance mode OR giving voice instruction regardless of pauseonvoice, gpsonvoice setting. What's you think?
    It's just a matter where to I put the indicator code setting. No thinking involve (litterally )
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  4. #194
    Woodbridge, VA
    Blog Entries
    55
    it can work with or without pauseonvoice enabled. gpsonvoice must be enabled for my addon app to work... basically it what it does is check a few pixels in the square area that the direction indicators are, so if gpsonvoice is disabled my app wont ever get updated data from the screen(i dont get an update when iG is in guidance mode because if your in guidance mode you should be on the gps screen anyway lol). So to keep it simple.. as long as gpsonvoice is enabled the indicator should turn on whenever iG speaks.
  5. #195
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    "onskinstart"
    "ONSKINSTART", I THOUGHT I had read about that command somewhere. It is NOT in the skincommands.txt file. I will IM Guino and see about getting it in there.
    My Fiero Build Thread
  6. #196
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by JohnWPB View Post
    ONSKINSTART is in exectbl.ini.
  7. #197
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    "onskinstart"
    Sonix, I realize it is used in the ExecTbl, but explanations of the commands are all in the skincommands.txt file, so someone knows that it exists, for one, and an an example of the syntax to use it. I am not POSITIVE, but my Original install of the ExecTbl is pretty much the way it came when I first installed RR ( change the one for the skin itself) , and the command is not in there by default. So, my point is, if it's not in the SkinCommands, and not in the ExecTbl by default, how would anyone new starting to skin, know anything about it?
  8. #198
    Mar 2005
    Sweden/Vaxjo
    actually in coding i've found the best way to get the most up to date turn is to have the indicator set to ON whenever autogps switches to the gps screen and OFF when it changes back to LASTSCR (regardless of whether its in guidance mode). And here's my progress so far today i have direction indicators working.. albeit in a crude way for the time being. the arrow is pulled directly from the gps skin and can be placed anywhere on any skin. Right now only way it works is if i manually start the exe i compiled but once the mods to your program are complete it will run once each time the indicator is set to ON.
    i plan on also including the data from the four bottom boxes of iG (eta etc etc) as well as autozoom based on speed.
    Lastly, should you not like the look of the standard iG arrows you can use any other .png image stored in your skin file.. so it doesnt HAVE to appear as it does below.
    Anyone know what font iG uses. That would help me move forward
    Damned... I've been away from the forums for 2 days or something and you make my dreams come true...
    I tried to read most posts but I'm feeling a bit tired (really long day at work today) but one small question... that little arrow up there does that auto-change after u have gone past it... hope u in some weird way can understand what I'm asking... if that's the case there's almost no reason why you would need it to change to IG, and thats bloody great.
    oh, could you either post that custom freedom header with some nice instrucitons on just send me PM... I'm using the same skin and that looks awsome...
    Swedish site for CarPC's
    http://www.bilpc.info
  9. #199
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Naesstrom View Post
    well technically you'd still have to go to ig to get the arrow . and yes one i made that left turn the next turn indicator pops up. If your not routing then its stays invisible. I actually need a few people to help me test what i have so far. You'd be surprised how much of a pain in the *** it is to test the Right U-Turn indicator in the united states lol. If anyone is interested in doing some very basic beta testing for me PM me.. but just know at this time the only skin this works with is freedoms full screen (gpsfull.skin) and it only works with ig3 UMPC edition.
  10. #200
    Mar 2005
    Sweden/Vaxjo
    Sounds real good... I'm up for some testing, I drive in my work everyday so I have plenty of time to find all the bugs... there might be one small catch though... UMPC version, never heard of it actually...
  1. Replies: 4
    Last Post: 01-26-2006, 03:35 AM
  2. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 03:02 PM
  3. Auto off switch
    By Ill1 in forum General Hardware Discussion
    Last Post: 01-17-2005, 03:50 PM
  4. auto start/shutdown with tower switch
    By HybridFox in forum General Hardware Discussion
    Last Post: 11-07-2004, 12:10 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
