Page 21 of 37 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 365
Thread: Auto switch to Guidance screen for iG?
  1. #201
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by JohnWPB View Post
    "ONSKINSTART", I THOUGHT I had read about that command somewhere. It is NOT in the skincommands.txt file. I will IM Guino and see about getting it in there.
    most likely from my skin or either Chucks, i believe our 2 skins may be the only 2 that require this command for the skin to work.
    It is included in the default ExecTBL.ini file for RR, but i do not believe that file gets updated on new RR updates (and shouldnt).
    There are a few ONBLANKSTART commands, they prob should be added to SkinCommands.txt
    beer replenishment fund
    mp3car live search
  2. #202
    Aug 2003
    Chicago
    Quote Originally Posted by Sonicxtacy02 View Post
    but just know at this time the only skin this works with is freedoms full screen (gpsfull.skin) and it only works with ig3 UMPC edition.
    will this eventually work with standard skins?
    mp3car live search
  3. #203
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by liquid_smoke View Post
    yes it will work with all skins once its complete
    Live mp3Car Facebook Chat
  4. #204
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    When do you plan on releasing this? This is great stuff.
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  5. #205
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Some good news on the "DING!"
    Ok Guys, some great news...
    I was just experimenting with the DING sound and it's annoying habbit of pausing the music. As mentioned before, putting a blank .wav file, it will still pause Winamp if you have the pauseonvoice=true set.
    Here is the good news, As you probably know, when winamp pause it is not an INSTANT pause, but a very fast ramp down. When it un-pauses it ramps up very quickly. REMOVING the Mvr.wav (The Ding Sound) from the iguidance/snd directory works! Let me explain "works"
    First off, iG seems to have no complaints about the sound not being in the directory (No Errors ect)
    When iGuidance accesses this sound, it starts to change the volume, when it is not there it resumes the normal volume level. This happens faster than winamp's ramp down on pause command can occur. You will hear a SLIGHT drop in audio if you are listening to music, but it is only about 5% before it just just goes right back to normal. This is FAR better than the DING which gives winamp enought time to pause, hear the sound, and then unpause. It's also better than an empty .wav file in it's place which just makes Winamp pause for the silence before resuming.
    I wrote a script linked to an OFF button, that simply copies the Mvr.wav file out of the snd directory to a temp directory, and can copy it back in with the press of the ON button. Using the EXISTS command, I change the indicator to give the status of the sound on/off.
    My Fiero Build Thread
  6. #206
    Sep 2006
    Sabattus, ME
    OMG my hero....
  7. #207
    Aug 2003
    Chicago
    nice,
    mp3car live search
  8. #208
    Constant Bitrate jeffreyd_tx's Avatar
    Sep 2006
    Wilkes-Barre, Pennsylvania, United States
    you need to turn on the feature first.
    pauseonvoice=TRUE
    you are also missing igautosw=1
    screen switching or anything else shouldnt work without this set. If it does then that should be marked as a bug. Non IG users likely wont like that.
    lastscreenswitchtime=5
    pauseonvoice=true
    gpsonvoice=true
    igautosw=1
    I was running winamp 5.xx. I installed 2.95 today and it works. I could not get it to play well with 5.
  9. #209
    Aug 2003
    Chicago
    Quote Originally Posted by jeffreyd_tx View Post
    the very latest versions of winamp has many issues with RR in general. The latest version that works with no issues is 5.1.3, anything newer and issues pop up.
    mp3car live search
  10. #210
    Sep 2006
    I switched to 5 for toaster support but the toaster pop ups are too small and useless anyway. Now Guino is developing a plugin for embedded tags that makes my need for 5 moot.
  1. Replies: 4
    Last Post: 01-26-2006, 03:35 AM
  2. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 03:02 PM
  3. Auto off switch
    By Ill1 in forum General Hardware Discussion
    Last Post: 01-17-2005, 03:50 PM
  4. auto start/shutdown with tower switch
    By HybridFox in forum General Hardware Discussion
    Last Post: 11-07-2004, 12:10 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
