Page 22 of 37 FirstFirst ... 121314151617181920212223242526272829303132 ... LastLast
Results 211 to 220 of 365
Thread: Auto switch to Guidance screen for iG?
  1. #211
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by JohnWPB View Post
    Ok Guys, some great news...
    I wrote a script linked to an OFF button, that simply copies the Mvr.wav file out of the snd directory to a temp directory, and can copy it back in with the press of the ON button. Using the EXISTS command, I change the indicator to give the status of the sound on/off.
    Good job
    Can you share it with us”
    2001 S10 ZR2
    Chucks Skin - to old
  2. #212
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    not to step on JohnWPB toes, i was a little lazy so i was just gonna wait for you to post your files, but then i got bored, and this is so simple to do, it only takes a few min to knock it out.
    toggle ding sound on/off
    Add this to ExecTBL.ini
    Code:
    "DINGOFF","SETVAR;igding;0||SAVETOINI;igding;$igding$"
    "DINGON","SETVAR;igding;1||SAVETOINI;igding;$igding$"
    "IGDINGTOGGLE","RUN;$rrpath$toggleding.exe"
    unzip the attached files in to the same dir as RoadRunner.
    toggleding.exe should be in the same dir as Road Runner.exe (no sub folders)
    Button Code:
    Code:
    "IGDINGTOGGLE"
    Label Code:
    Code:
    "BYVAR;igding;=DING OFF<<=DING ON"
    Add to RR.ini (optional, this will get added the first time you run the tool)
    igding=0
    This should give you one button that will toggle the feature. Its pretty much the exact same thing as what JohnWPB did, except i think he used 2 buttons one for on one for off and my version is a toggle button.
    source au3 file included.
    Attached Files Attached Files
    beer replenishment fund
    mp3car live search
  3. #213
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Scipts
    Very Good LS. I didn't look at your code, but I made the mistake in my first version of not checking if the temporary folder existed or not first
    In my case I simply created a temp folder in the iguidance\snd directory to copy the file into to turn the sound off. And if this is what you did also, moved the file out of the snd dir, os I just use an "EXISTS" command for the indicator, and not need it in the rr.ini at all. This also works if you manually move the file, it will update on the RR screen instantly, and has NO way to get "out of sync".
    I am not as proficient with AutoIt, and am really good at VBScript, thus the code I wrote is in .VBS, and is executed with the WSScript command.
    The scripts are in my skin, linked in my sig, but I will zip it up and post it back here in this post if does want it without the 10 meg download.
    The script checks to see if the temp folder exists, and if not creates it, then if you select OFF it will move the ding sound to the tenp dir, if it's off, it will just move it back to the main snd directory.
    EDIT:
    Ok the script is attached below.
    First download the script, and put it in a path of your choosing, (I created a folder named iGScripts in the Root Road Runner Folder)
    To activate it, put this code on your button:
    "RUN;wscript.exe|"C:\Program Files\Road Runner\igscripts\iGDingToggle.vbs""
    (Changing the path to where you put the Script file)
    For an indicator, to tell if it is ON use this command:
    "EXISTS;C:\Program Files\iNav\iGuidance\Snd\Mvr.wav"
    If you want an indicator if it is off as well then use:
    "EXISTS;C:\Program Files\iNav\iGuidance\Snd\temp\Mvr.wav"
    My Fiero Build Thread
  4. #214
    Aug 2003
    Chicago
    ah you just reminded me of the one thing i forgot, to create the temp folder if its not already there. So here is an updated version that fixes that.
    Im also including the Mvr.wav file incase anyone lost this file trying the earlier version.
    mp3car live search
  5. #215
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    [/B]
    Windows scripting???? mannnnnnnnn, that was like 10 years ago when I wrote some script as a system administrator.
    Anyway, I am trying to get into AutoIt as many of you are using it.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  6. #216
    Sep 2006
    Sabattus, ME
    your a Sys Admin matrix?
    So am I, or at least i am in the process of becoming one
  7. #217
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by SangreDeThor View Post
    When i worked at a small company, basically a 1 man show. Help desk, system admin, webmaster, web dev, .... The good is you have all opportunity to try and play. The bad is you have to hit the web for help and stay late if you screw up. .
    Not anymore, a programmer instead
  8. #218
    Constant Bitrate jeffreyd_tx's Avatar
    Sep 2006
    Wilkes-Barre, Pennsylvania, United States
    Can rr see if winamp is already paused before it tries to pause/unpause?
    I almost had a heartattack when rr unpaused my winamp after an ig voice prompt.
  9. #219
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Heheheh I'm with ya! I had something similar happen last night. Was on the way home, and paused Winamp when the phone rang... was talking about 10 minutes before IG told me to get off at the next exit and then Winamp started back up.
    It should be possible, when the Guidance or Voice triggers, to check the status of Winamp. As I reported a few posts back, I had it get out of sync a couple times. Where Winamp would un-pause when iG was speaking and then pause when iG stopped speaking.
    The question is is there a way to send SEPARATE pause and Play commands to Winamp, or is only the toggle available?
  10. #220
    Sep 2003
    Beach City, Socal
    I can check for winamp without any problem, but what about other players (Radio, Sat Radio, Video, .... )?
  1. Replies: 4
    Last Post: 01-26-2006, 03:35 AM
  2. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 03:02 PM
  3. Auto off switch
    By Ill1 in forum General Hardware Discussion
    Last Post: 01-17-2005, 03:50 PM
  4. auto start/shutdown with tower switch
    By HybridFox in forum General Hardware Discussion
    Last Post: 11-07-2004, 12:10 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
