Page 28 of 37 FirstFirst ... 1819202122232425262728293031323334353637 LastLast
Results 271 to 280 of 365
Thread: Auto switch to Guidance screen for iG?
  1. #271
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by JohnWPB View Post
    That Shouldn't be necessary... There's an option in AutoIt to do the pixel search based from the top left corner of the application, and NOT the screen. Therefore, the pixel location shouldn't change from one GPS screen to another, or even Skin to Skin for that matter.
    This would for instance get a pixel color from the top left of th IG screen, and not the entire screen:
    Code:
    WinActivate ("iGuidance")
    Opt("PixelCoordMode", 0)
    $Guidance = PixelGetColor( 61 , 109,)
    i tried this again and as i thought autoit cant get focus of iguidance when ignative is set to true. I even tried it with Opt("WinSearchChildren", 1)
    Live mp3Car Facebook Chat
  2. #272
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Sonic, this is the problem I posted in the earlier day of iGnative. If you can read RR's label with your app, you can use IGHWND label. It is a window handler for IG when iG is running regardless native or not. IGHWND is set to 0 when not running.
    I am not use how you use it with autoIt. Normally, that is the long value return back when you use any of windows api to look for an app.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  3. #273
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by MatrixPC View Post
    i can read the label but how does that allow me to activate ig's window so i can do a pixel search? Reading the label returns this to autoit:
    Code:
    IGHWND||459826
  4. #274
    Woodbridge, VA
    Blog Entries
    53
    wow... via dumb luck i was able to figure it out. i was also able to figure out how to read the ig screen when it not even visable. Gonna have to use that!
  5. #275
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    seems to be some issues with the latest beta, everything was working fine before the code merger, now if i dont have IGAUTOGPS set in my ExecTBL.ini nothing will happen, and when i do have it set it switches to GPS on voice but never switches back.
    Ill do some more testing and try to narrow it down.
    beer replenishment fund
    mp3car live search
  6. #276
    Sep 2003
    Beach City, Socal
    hm.... I don't have the code after guino merged with his.
    He said that he made a few change regarding to those commands. So far, my test show that it worked like before.
  7. #277
    Aug 2003
    Chicago
    did he say what he changed or if we need to change anything on our end.
    the pause/resume works fine
    but nothing else seems to work for me now, i havnt changed anything but the update, ill keep playing with it.
    mp3car live search
  8. #278
    Sep 2003
    Beach City, Socal
    I don't know, I just have to look at the actual code. The problem could be the custom command in ExecTBL.ini associate with those IGxx command. The default IGPAUSE=PAUSE should work fine.
  9. #279
    Aug 2003
    Chicago
    well i got it to switch back by adding
    "IGAUTOGPSEXIT","LASTSCR"
    without it, it wont do anything.
    Just to clarify everything.
    my rr.ini
    igautosw=True
    pauseonvoice=True
    lastscreenswitchtime=5
    gpsonvoice=True
    if i remove any and all commands from ExecTBL.ini that are related to igautosw, the only thing that works still is the pause winamp when ig speaks.
    To get RR to switch to GPS i have to add
    IGAUTOGPS and IGAUTOGPSEXIT commands to ExecTBL.ini, even though its turned on in RR.ini
    mp3car live search
  10. #280
    Woodbridge, VA
    Blog Entries
    53
    having the same issue and the igind seems to turn off and on on its own at times. if an instruction occurs within like 10 seconds of a previous one the indicator stays on throughout both instructions.
  1. Replies: 4
    Last Post: 01-26-2006, 02:35 AM
  2. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 02:02 PM
  3. Auto off switch
    By Ill1 in forum General Hardware Discussion
    Last Post: 01-17-2005, 02:50 PM
  4. auto start/shutdown with tower switch
    By HybridFox in forum General Hardware Discussion
    Last Post: 11-07-2004, 11:10 AM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
