Page 3 of 37 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 365
Thread: Auto switch to Guidance screen for iG?
  1. #21
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    waiting with great excitment
  2. #22
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Well, it's almost a month since I first post. As of now, I still have no idea how to detect when iG gives instruction. iNav make it so freaking difficult to detect the event. I kind of don't want to go the route that iGmon did by comparing sound level. In the mean time, the best option I could do is detect when Guidance screen come up then execute GPS command.
    Hopefully I'll have it done by holiday travel time (X-mas) or whenever next offical RoadRunner release.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  3. #23
    Sep 2006
    Sabattus, ME
    I hope so too
  4. #24
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    iGuidance Automatic Screen Switching with Audio
    I know you said you don't want to go the route of detecting the audio, but it may be the best way to go.
    When I had iGMon set up with iG 2.x, it worked VERY well. The other advantage is, whenever iG speaks something, that is the perfect time to bring the screen to the front. EA: On a highway it will usually tell me "Turn Right in 2 miles", on a slower street, it may say it at a much shorter time before the turn. Regarless, when iG speaks, that is when it is trying to get you attention, and the screen changing at that time would be spot on.
    It would also negate the need to try to get into iG's code, which is quite elusive, as you mentioned.
    My Fiero Build Thread
  5. #25
    Sep 2003
    Beach City, Socal
    Alright guys, I need some input from you guys to make this thing rolling.
    In order to use the sound level comparision I need to know the following 2 settings.
    What is the typical wave volume setting you guys have in the mixer?
    How often you guys change this setting?
    Does other player, XM, Sirus, FM, WinDVD, PowerDVD change the setting by itself? I think PowerDVD change the wave setting on start up.
    what setting you guys has for iGuidance?
    Let say, in the mixer, you guys set the wave slider to 50%, iGuidance volume setting has to be somewhere higher 60% for sound level comparision to work.
    Basically I'll try to read the current wave volume then check when this level change and automatically switch to GPS screen.
    So far, the method of looking for "Guidance" windows work really well, but that slow down the system if you playing DVD or Video (so much resource intensive) and I have to find a different way of doing it.
  6. #26
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    hate to throw another idea in the hat when u seem like ur goin this direction but why not monitor the access of the .wav files in the iguidance directory? That way the actual volume wouldnt matter.
    Live mp3Car Facebook Chat
  7. #27
    Sep 2006
    Sabattus, ME
    thats a good idea sonic. that would negate the volume issure if one were able to monitor file status. which should be able to be done. another idea would that it doesnt need to run constantly put it to sleep would be useful, like run every 5 sec, or 10? that way it might not be as intensive. what y'all think?
  8. #28
    Woodbridge, VA
    Blog Entries
    55
    autoit can scan a folder of 100 files for usage every second without making the cpu hiccup i've done it before.
  9. #29
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Sonicxtacy02 View Post
    Actually, the idea of looking at the sound directory of iGuidance has been brough up before, but also been scrap. The idea is checking the directory/file for last access time isn't accurate as it was mean to be. This is because WinXP doesn't constantly update last access attribute of the files. So checking it for last access is useless. Check this thread for more Navigation Mute
    I don't know how autoIt check for the files, but if it rely on LastAccessTime attributes, it will fall in the same boat as above. Also, keep autoIt constantly running will slow down the system for sure.
    Anyway, if you guys has other idea, just throw it out and maybe we can come up with something. As of now, I will go with checking for Guidance screen and monitor the sound level on the wave line.
  10. #30
    Woodbridge, VA
    Blog Entries
    55
    actually auto-it uses an advance last access attribute that proves the information real-time. I'll have to work somethin up when i have the time as its been awhile since i used those functions.
  1. Replies: 4
    Last Post: 01-26-2006, 03:35 AM
  2. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 03:02 PM
  3. Auto off switch
    By Ill1 in forum General Hardware Discussion
    Last Post: 01-17-2005, 03:50 PM
  4. auto start/shutdown with tower switch
    By HybridFox in forum General Hardware Discussion
    Last Post: 11-07-2004, 12:10 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
