Page 4 of 37 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 365
Thread: Auto switch to Guidance screen for iG?
  1. #31
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    iGuidance Screen Switching
    I have been trying to figgure this out from all different angles as well. I wrote a fast and crude script to determine if iGuidance is notifing you of an upcoming turn. This is done by looking for the "Olive Green" top bar that show's up when a turn is approaching. Right now it will only work if the iGuidnace screen is on top, and showing. Thus, the only thing it could be used for currently is pausing winamp or something.
    I THOUGHT there was a way to "go behind" the current window, and check for Pixel color, but I haven't found a way as of yet. I THINK that's how iGMon worked. If that can be worked out, this may be a sollution.
    here is a script EDIT: Read 4 posts down, There is a MUCH improved version to try out now
    My Fiero Build Thread
  2. #32
    Sep 2006
    Sabattus, ME
    thats nice. that would be a nice feature to implement in your skin so when iGuidance is giving directions you could pause the music. what 'ya think? now what where do i get autoIT and is it in c++? i am going to learn c++ i think to try to contribute a little bit more
  3. #33
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    AutoIt
    AutoIt actually uses it own scripting language. You can Find AutoIt Here. (It's COMPLETELY FREE)
    The nice thing is when the script is compiled with AutoIt, it makes it into an .exe that will run on a system without AutoIt installed.
    From the Help File:
    AutoIt has a much more standard syntax -similar to VBScript and BASIC
    It's great for automating ALL sorts of Stuff, not just stuff for a CarPC.
    As for putting it in my skin, that is the final intent. I will hold off a while and see where we get with the FULL functionality of pausing the music AND switching to the GPS screen as well.
  4. #34
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Hey JohnWPB and everyone else, if you guys want to test your script in real world without put it in the car and driving around or play back a pre-recorded gps stream, do this.
    Pick a destination and start navigate. iG will say "waiting for GPS signal".
    Go to File -> Start Demo. iG will start navigate to the selected destination in demo mode. It is the same as real time navigation mode.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  5. #35
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    WooHOO!!!!!!!!!!!!!!!!!!
    It's Getting Somewhere!!!!! b8bboi answered me back, and told me to use the ControlGetHandle to find if iGuidance has switched to the guidance screen, instead of the pixel color that I was using..
    This also works when iGuidance is MINIMIZED, OR if it is HIDDEN in Road Runner!!!!!!
    Someone else please test this out on their machine to confirm, but this was/is a MAJOR hurdle to overcome to get this to a finished product, that can pause winamp, and bring the GPS screen to the front.
    Right now, it is just a message box that will pop-up to let you know if it switches to Guidance, or switches back. The msg box will dissappear after 1 second. The next step would be to take that msgbox "trigger" and put it to use to switch the RR screens, and/or winamp volume/pausing.
    Here is the file, just unzip it and run it, then fire up IG either standalone or in RR. (In Standalone you can use the toolbar to switch between map & guidance & You can also set a route and demo it like Matrix said in the last post). A trick I have been using for a while to test stuff
    Attached Files Attached Files
  6. #36
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    working here
    ver 2.1.2NA
    2001 S10 ZR2
    Chucks Skin - to old
  7. #37
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    The Bad.... and the Good
    Thanks Chuck! That shows it also is "backwards Compatible with earlier versions of IG". Unfortunately. this is only the first hurdle. , it can't be used to pause winamp or lower the volume correctly Right now. I have it pausing WinAmp when the Guidance window comes up, and resuming when it goes away, and they are WAY out of time with the voice.
    Speech in IG seems to have it's own set of timing, and is not related to the Guidance payne. For instance, iG will tell you turn right in 2 miles, but the Guidance screen will not come up till a short time before the actual turn. Also if you are making a left at a red light, the guidance screen will remain in place till you clear the intersection, keeping the music paused all the while.
    On the bright side, this WILL work for switching the iGuidance to the front when a turn is approaching, and switch back when completed.
  8. #38
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Ok, So I'm on a roll
    Here is a rough draft of how it will work in a real world situation. The script below will actually switch the screens in Road Runner. I found code in the Road Runner SDK examples written by b8bboi to send commands to RR from an AutoIt script, so many thanks to b8bboi for that!
    Download, and run the script, it will show in the system tray. Fire up Road Runner, and go to iGuidance, Drag to a place on the map a few miles away, and click and hold and choose "Set Destination". Then click the Iguidance Menu button, choose destination, and choose DEMO. iGuidance will start to do that route in demo mode. You can then go to the main menu, or any other screen, and sit back and wait. You will hear iGuidace giving dirrections and distances ect, but when the turn gets close, the screen SHOULD switch back to iG. When the turn is completed, it again SHOULD put you back on the screen you were on.
    There are still a few kinks to work out, and polish it up, but it's getting better!
  9. #39
    Sep 2006
    Sabattus, ME
    nice i will try it out tonight when i get home. graet work JohnWPB
  10. #40
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Works well
    It might be better if you use a different command then “GPS” so you could do other stuff too.
    SendCommand($My_Hwnd, $hwnd_RR, "GPS")
    SendCommand($My_Hwnd, $hwnd_RR, "AUTOGPS")
    “AUTOGPS”,”BYVAR;GPSFULLSCREEN;GPS<<GPSFULL”
    2001 S10 ZR2
  1. Replies: 4
    Last Post: 01-26-2006, 03:35 AM
  2. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 03:02 PM
  3. Auto off switch
    By Ill1 in forum General Hardware Discussion
    Last Post: 01-17-2005, 03:50 PM
  4. auto start/shutdown with tower switch
    By HybridFox in forum General Hardware Discussion
    Last Post: 11-07-2004, 12:10 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
