Page 5 of 37 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 365
Thread: Auto switch to Guidance screen for iG?
  1. #41
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    latest rr
    iG V3 Native
    I dunno if its my computer (slow) but it didnt consistently change to the Ig skin. However when the turn was completed the screen did always go back. This is progress though
    Live mp3Car Facebook Chat
  2. #42
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by Chuck View Post
    Works well
    It might be better if you use a different command then “GPS” so you could do other stuff too.
    SendCommand($My_Hwnd, $hwnd_RR, "GPS")
    SendCommand($My_Hwnd, $hwnd_RR, "AUTOGPS")
    “AUTOGPS”,”BYVAR;GPSFULLSCREEN;GPS<<GPSFULL”
    i was just thinking this. having a command that you can define urself in exectbl.ini would make it more flexible.
  3. #43
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I agree 100% that it needs to be a .ini setting. This was just a test, and I will incorporate pulling a line from an ini in the near future. Glad to see that it is somewhat working on other systems for sure! That alone is promissing, and hopefully a good start.
    As for it not switching to the IG every time.... Not sure what that could be as of yet. It should not bee too processor intensive. It "polls" the iGuidance screen every half second. On my 3Ghz machine, it never goes above 2-3% CPU usage when the script is running. This could however be another INI setting, the time interval the script polls iG.
    Right now, I have to get away from the computer for a while, I'm getting BUG EYED!! Will work on it more later this evening.
    My Fiero Build Thread
  4. #44
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    JWPG
    Good work there. Sorry I didn't get back to you regarding to IM as I don't (can't) use one where I am at now.
    Anyway, I already have the Guidance screen detect and switch to GPS mode and switch back to lastscreen. Work well without slowdown the system as my previous method.
    The next thing I'll do is detect when iG given voice direction and pause curent player. And resume when voice is gone.
    I'll probably have a beta release today. This will work with both version of iG 2.x and 3.0 as well as iGnative or not.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  5. #45
    Apr 2005
    Queens, New York
    This does not seem to be working for me unfortunately...Maybe because my ig is iguidanceUMPC.exe?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  6. #46
    Mar 2005
    Sweden/Vaxjo
    Hi there!
    I'm having problems getting it to work 2...
    running latest RR, IG 2.1.2UK and freedom skin, I started the file and at first it was paused in the tray so I started it, ran RR and IG in demo mode but it didn't matter what screen I was on it never switched to IG when it was showing that screen... it just turned up the volume as usual...
    Swedish site for CarPC's
    http://www.bilpc.info
  7. #47
    Sep 2003
    Beach City, Socal
    Alright guys, those who want the beta PM me your email address.
    The code is base on offical Oct 8 release of RoadRunner .
    What does this beta has?
    - Fixed the problem with switching between VIDEO and DVD when using build in Video player and MPC for DVD. Currently, you can't do that. This issue brought up before but I am busy and lazy to release it for Oct release.
    - Auto switch to iGuidance GPS screen (use GPS command) when iG's Guidance screen come up, and on voice direction.
    - Auto switch back to LAST screen X seconds after voice finish or Guidance screen disappear.
    - Option to pause/resume current player (via PAUSE and RESUME command) on voice instruction. I found that pause and resume music isn't an idea if voice instruction is on every couple seconds, especially when there is a DING sound, but you guys can try.
    - This mod should work with iG 2.x, iG 3.0, and iGUMPC 3.0 regardless of iGnative is set to true or false.
    To use:
    Modify RR.ini to include the following setting.
    lastscreenswitchtime=[0-10]
    Default is 0. How many seconds for RR to switch to Last screen after Guidance screen disappear or Voice instruction finish. 0 to disable auto switch to Last Screen (You manually hit whatever screen you want or stay in GPS screen). Default is 0 => Stay in GPS screen.
    pauseonvoice=false
    Default is false. If set to true, RR pause current player via PAUSE command and resume when voice instruction is finished.
    gpsonvoice=true
    Default is true. When set to true, RR will automatically switch to GPS screen (if not already in). And depend on lastscreenswitchtime, RR will switch to last screen or not.
    RR will always switch to GPS screen (if not already in) when Guidance screen come up.
    Also, Open you mixer and adjust the volume on WAVE so that the level is at least 5% different from iGuidance volume level. This is a must for Voice detection to work. Also make sure NO other external player (WinDVD, PowerDVD) trying to change the volume to about the same level as iG.
    Note: Anyone use any custom command to load iGuidance, make sure you add/modify it in Exectbl.ini to have "GPS" execute that custom command.
    Let me know if there is any bug.
    JohnWPB, I am sorry if this release seem to conflict with what you trying to do. Seriously, I really don't like the idea of having autoIt scripts running fulltime with the system.
  8. #48
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Is there a way to turn on and off the auto switch with out restarting RR?
    Will this go to last screen if you go to GPS manually and want to stay there?
    2001 S10 ZR2
    Chucks Skin - to old
  9. #49
    Sep 2006
    Sabattus, ME
    MatrixPC: how are you testing to see if iG is speaking? as in the actual code because i already know how to test it with the demo mode
  10. #50
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    I think it would be a good idea to activate commands instead of RR doing the switching screens. That way all users could change stuff to do it the way they want or standard way.
    So if the new stuff would just Activate "IGAUTOGPS" and "IGAUTOGPSEXIT"
    Standard way
    "IGAUTOGPS",”GPS”
    "IGAUTOGPSEXIT",”LASTSCR”
    Or the way I would do it.
    1 a way to turn on and off .
    2 a way not to go to last screen if you go to GPS manually.
    3 a way to go to the GPS full screen or standard GPS.
    /,65A--------------------GPS Auto Switch Screen--------------------------
    "IGAUTOGPS","BYVAR;AUTOGPSSW;<<AUTOGPSYES"
    "AUTOGPSYES","SETVAR;GOGPS;0",EXTERNAL_GPS.ski n
    "AUTOGPSYES","BYVAR;FULLSCRN;GPS<<GPSFULL||SETVAR; GOGPS;1"
    "IGAUTOGPSEXIT","BYVAR;GOGPS;<<LASTSCR"
    /,-----------------------GPS Auto Switch Screen Button on off----------------------
    "AUTOGPSBT","BYVAR;AUTOGPSSW;AUTOGPSON<<AUTOGPSOFF "
    "AUTOGPSON"," SETVAR;AUTOGPSSW;1"
    "AUTOGPSOFF","SETV AR;AUTOGPSSW;0"
    2001 S10 ZR2
  1. Replies: 4
    Last Post: 01-26-2006, 02:35 AM
  2. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 02:02 PM
  3. Auto off switch
    By Ill1 in forum General Hardware Discussion
    Last Post: 01-17-2005, 02:50 PM
  4. auto start/shutdown with tower switch
    By HybridFox in forum General Hardware Discussion
    Last Post: 11-07-2004, 11:10 AM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
