Page 9 of 37 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 365
Thread: Auto switch to Guidance screen for iG?
  1. #81
    Jun 2006
    Ok - gotta luv it, I have been out of the country for a week and all of this excitement in a great thread I am trying to digest and figure out
    Chuck is your skin packaged up with all of these mods so I could see what you are doing per this post. This is of VERY MUCH interest to me the added approach you took....
    Thanks for the great work here guys - this was a killer need and sounds awesome...
    Quote Originally Posted by Chuck View Post
    I like this thing so much I added another mode to my button so IG will popup in any player play list. Audio, Radio, XM, Sirius
  2. #82
    Jun 2006
    Matrix --
    Same issue here with no pause, seems to be working with the test suggestion but no pause --- did this get posted yet so I can be sure to test the one referenced here .... Or if anyone else has...
    Thx all
    Quote Originally Posted by MatrixPC View Post
    Hey Sorry everyone.
    My bad. Before I compile to exe, I commended out the code that Pause and Resume music (because the DING sound drive me nut ). The exe you guy have will NOT pause/resume music.
    Naesstrom, I'll send the update to you so you can host for everyone to download.
  3. #83
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Here is my updated skin with this stuff in it
    http://mywebpages.comcast.net/charle...ucksSkinVI.zip
    2001 S10 ZR2
    Chucks Skin - to old
  4. #84
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Talking Chuck's Skin
    Chuck, Yikes, I'm actually scared to look at it Your code is usually way over my head to try to figgure out how you accomplish some of the stuff you do
    My Fiero Build Thread
  5. #85
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I haven't look at Chuck's skin stuff yet, but I am sure I need good clarification/explaination on line-by-line. I hope that one I understand, I can hopefully modified RR to have it full control on manual/auto switch.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  6. #86
    Jun 2006
    Chuck - this is an interesting idea and will dig thru your skin - which I agree is usually some heavy stuff but killer learning grounds.....
    As for this piece - how are you doing this, an added Application overlay to the playlist area and then when it goes active it just consumes that spot then disappears? Please let us know as that indeed is a neat concept...
    Thanks....
  7. #87
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    I hope this will help
    If anyone has any questions just ask
    Code:
    Step by Step for Multiple auto switching GPS screens and off with MatrixPC's - Auto switch to Guidance screen for iG?
    I only had to add a few lines of stuff in the ExecTBL.ini file to do all this. I already had my skins made up so I could use any player with GPS.
    First thing you need to make is skins for all the skins you want to use with GPS. This is easy just copy your player you want to use and add an APPLICATION area over the play list or where ever.
    /, A, x, y, w, h, color;RGB
    A01,361,194,542,298,000
    Then name the skin something like AUDIO_GPS.skin or FS_GPS.skin
    Next you need a way for Auto switch to open the skins with the load command and name that command in the ExecTBL.ini file
    “AUDIOGPS”,”AUDIO||LOAD;AUDIO_GPS.skin;audio gps;C:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance||SETVAR;ATVP;1”
    “XMGPS”,”XM||LOAD;XM_GPS.skin;xm gps;C:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance||SETVAR;ATVP;2”
    “SIRIUSGPS”,”SIRIUS||LOAD;SIRIUS_GPS.skin;sirius gps;C:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance||SETVAR;ATVP;3”
    “RADIOGPS”,”RADIO||LOAD;RADIO_GPS.skin;fm gps;C:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance||SETVAR;ATVP;4”
    “GPSFS”,”LOAD;FS_GPS.skin;gps full screen;C:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance”
    The SETVAR;ATVP;x at the end of each line above is so Auto switch knows what player you are currently using.
    You also need to add setvar;atvp;x to the end of all your other standard players command lines.
    "AUDIO","LOAD;Audio_Player.skin||SETVAR;ATVP;1"
    "XM","LOAD;XM.skin||SETVAR;ATVP;2"
    "SIRIUS","LOAD;SIRIUS.skin||SETVAR;ATVP;3"
    "RADIO","LOAD;Audio_Player.skin||SETVAR;ATVP;4"
    You will also have to add or rename your currant "GPS" command because Auto switch uses this command to activate gps screen.
    “IGGPS”,”LOAD;EXTERNAL_GPS_IG.skin;gps;C:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance"
    Now the commands for the actual sawitching - the "GPS" command sent from Auto switch
    This line will run a skin depending on the button setting you have selected.
    "GPS","BYVAR;AUTOGPSSW;<<IGGPS<<GPSFS<<AUTOGPSPLAYER"
    This line will determine what player to put the gps screen in – set at the end of each player command line above
    "AUTOGPSPLAYER","BYVAR;ATVP;<<AUDIOGPS<<XMGPS<<SIRIUSGPS<<RADIOGPS"
    This is the button command for the different modes -OFF-GPS-GPS full screen-GPS
    "AUTOGPSBT","BYVAR;AUTOGPSSW;SETVAR;AUTOGPSSW;1<<SETVAR;AUTOGPSSW;2<<SETVAR;AUTOGPSSW;3<<SETVAR;AUTOGPSSW;0"
    This is the button that needs to be added to your GPS skin or in any skin for settings.
    B,x,x,x,x,"AUTOGPSBT",""
    this is the label for the the button and tell you what mode your in.
    L,x,x,x,x,224,223,227,16,"Arial","BYVAR;AUTOGPSSW;-Off<<=AUTO<<=A-FULL<<=A-Player","CENTER"
    2001 S10 ZR2
  8. #88
    Sep 2003
    Beach City, Socal
    Now that is freaking interesting. RoadRunner is truely the MOST flexible, customize player of all time.
    My only recommendation to the above is this
    Instead of typing on every lines
    You should use (if you setup GPSPATH and Name in RRConfig for Iguidance)
    $GPSPATH$;$GPSNAME$
  9. #89
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Yap, I am still in the days of setting MM in the RRConfig so the comport would work RR stuff.
    2001 S10 ZR2
  10. #90
    Sep 2003
    Beach City, Socal
    Alright guys, so far, I use it over the weekend and all work as expected. However, during development, I found a BIG BUG that I could NOT replicate (as I forgot exactly what I did). The problem is that you STUCK in GPS screen (the one that auto switch to), because RR keep execute "GPS" command. I can not go to any screen. I have to kill RoadRunner and re-start it.
    I try all posible combination I think I did, but I can't reproduce the bug. Basically I use RR's CLOSE command to close iG screen during auto switch to GPS (either by Voice or Guidance I forgot).
    Let me know if any of you run into this problem. Base on the code, I don't see anything that can cause a bug that BIG. aren't all programmers said that?
    Anyway, report all bugs so I can fix them before I send the code to guino by the end of the month for November offical release (if there is one) .
    Lastest download can be found on post 54. Thanks 65coupei6 for hosting the file. RoadRunner_auto-iG-10-20B.zip is the file name of latest release. RoadRunner_auto-iG-10-19B.zip is the one without pause/resume music.
  1. Replies: 4
    Last Post: 01-26-2006, 03:35 AM
  2. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 03:02 PM
  3. Auto off switch
    By Ill1 in forum General Hardware Discussion
    Last Post: 01-17-2005, 03:50 PM
  4. auto start/shutdown with tower switch
    By HybridFox in forum General Hardware Discussion
    Last Post: 11-07-2004, 12:10 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
