kpjuk: I had emailed silabs last night. I went through registering on their site to check their known issues and found they didn't have any app notes or documentation for supporting the chip/reference aside from those on the plain old extranet. I did notice they produced a more modern version of the chip which has a smaller die, but no code specific to it that I could examine to see if they cured the problem.
Mr. FMode,
(note, some clipped text)
1. My email is cactus_stew at yahoo. I appreciate your kindness to offer the RDS Interpreter data.
2. I am aware of the operation of masking it with the 16th bit and shifting right 4, but the issue was with the fact that it is using a non-RDS register. Note the registers[0xb], where registers[0xd] is defined as RDS Reg B and registers[0xb] is defined as READCHAN. I am curious if your code will parse the data on the firmware I have due to your sample code looks directly at RDS registers only and the silabs product seemingly uses undocumented data elsewhere.
3. I Will be happy to test anything related to the special PI codes and post/email you results.
Best Regards,
LinkBack URL
About LinkBacks
