Results 1 to 3 of 3
Thread: Launch PhoneControl through APPS
    Variable Bitrate seninha's Avatar
    Dec 2005
    As the skin that I use (Mauri V5) doesn't support Phone I tried today to start PhoneControl using APPS.
    I made a new map in the map LAUNCH. The I copied the INI file from one of the others and chaged the pad.
    But somehow Phonecontrol doesn't start.
    Can someone give me the right information that I need to put in the ini file to make sure this works
    Gods right foot!!
    Renault Grand Espace 3.5 V6
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you can simply copy the phonecontrol skin files from another skin into Mauri's skin and it should work directly in RR -- it's definitely better than try to run it embedded in RR.
    Ride Runner RR's Myspace
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    best t0 initially use Robby's skin and then gradually edit the files to match the skin you are using.
  1. Phonecontrol and Motorola v3
    By kyrenia in forum PhoneControl
    Last Post: 06-07-2007, 10:49 AM
  2. Centrafuse Embedded Apps Launch on Startup?
    By siliconkibou in forum Centrafuse
    Last Post: 10-03-2005, 08:54 AM
  3. hotkey to launch apps from app screen?
    By yalborap in forum FrodoPlayer
    Last Post: 02-21-2005, 04:55 PM
  4. Changing how external apps are watched
    By SJC in forum Media Engine
    Last Post: 05-26-2004, 04:55 PM
  5. How do you add app's to the Launch section
    By VWTronics in forum MediaCar
    Last Post: 11-10-2003, 09:42 AM
