Results 1 to 4 of 4
Thread: command "DIRECTION" & Map Monkey
    Dec 2005
    Hi.
    I have the small problem....
    Is it possible to see the images "direction" using "Map Monkey" like "freedrive" in the "Road Runner" program?
    Will you please help me ?
    Thany you!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the "DIRECTION" >indicator code< should work for both MM and FD. But you must have them propperly configured for that to happen -- for MM you have to use Advanced Mode with a NMEA GPS with the TCP integration in place -- check the FAQ. For FD, you have to tell it to send all data to RR (in it's INI).
    Ride Runner RR's Myspace
    Dec 2005
    thank GUINO,
    sorry...but i don't unterstand....
    In MM i have set "Advanced Mode with a NMEA GPS" but where is the "TCP" setting?
    Is possible to write me the link for this problem..?
    thank guino
    sorry for my english!!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Read the Map Monkey Section of this FAQ:
    How do I setup my GPS Application ?
  1. Replies: 106
    Last Post: 10-20-2008, 09:09 AM
  2. Map monkey just closes - wrong maps
    By clemen in forum Map Monkey
    Last Post: 03-02-2006, 04:03 PM
  3. Few Questions About Map Monkey and Destinator
    By Yevgeny in forum Map Monkey
    Last Post: 08-10-2005, 05:00 PM
  4. Replies: 3
    Last Post: 02-03-2005, 12:11 PM
