Results 1 to 3 of 3
Thread: How to get the full path of a customdl list item?
    Mar 2006
    Question How to get the full path of a customdl list item?
    as in the topic:
    I have an extension plugin and would need the full path of the currently selected dl list item.
    The same for the playlist would also be nice - currently i can retrieve it from the winamp.m3u file....
    Any help would be appreciated...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This is a relatively advanced topic. From the extension plugin, you have access to the Calling Screen's objects when a button/command is executed from it. So you CAN access that data directly when processing button codes. An example of this method would be (from the ProcessCommand function):
    case "plugin_showpath"
    msgbox frm.DL.Path + frm.DL.GetItem(frm.DL.Value)
    Add the above and make a button in the audio browser with that code and when pressing it, a messagebox with the path to the item selected will show. You'd have to look at RR's frmSkin's objects and their properties to know what all you can/can't do.. this does not
    However, if you wish to access such information on a timer basis, you can request "DLPATH" and "DLTEXT" via SDK's request commands -- this would require you to add a form (even if hidden), to implement the SDK support to receive messages from RR.
    Ride Runner RR's Myspace
    Mar 2006
    thanks for the quick answer!
    Is there also a way to get the path of an item in the playlist? It seems that the playlist array is not visible from the plugin...
  1. CENTRAFUSE BETA 2 [1.4] Requests
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 10:15 AM
  2. Replies: 11
    Last Post: 06-08-2006, 11:43 PM
  3. NMEA extraction AppleScript need help
    By zapwizard in forum MacCar
    Last Post: 05-05-2006, 01:10 AM
  4. Help w/XM list box not appearing
    By Viscouse in forum RR Skins
    Last Post: 02-15-2006, 10:44 PM
  5. thumbnail view for folder and list view for file?
    By civic5zigen in forum Road Runner
    Last Post: 11-01-2005, 12:55 AM
