Label with word wrap
Guino would it be easy and possible to make a label with word wrap option for tall labels?
L69,289,211,400,500,224,223,227,10,"Arial:B","=$TE XTHELP$","word wrap"
Chuck, I've added a wrap option for next release, but the "Scroll-up" option is the only current option that wraps the text.
Ride Runner RR's Myspace
Thx guino
I guess I should have explained myself a little better
I meant a label with multiple lines with word wrap
Hey Chuck,
a quick off topic . . . . Have you got any examples of a button swapping between 3 options. I want to create a menu button that when you press it, changes the button defs on the other 7 buttons. I can get it to work for 2 sets of options, but not for 3 !
what I mean is
b1 b2 b3 b4 b5 b6 b7 menu
When the skin loads up b1 = PREVIOUSTRACK
Press menu and b1 changes to GPS
press menu again and b1 changes to GAMMA
press it again and b1 goes back to PREVIOUSTRACK
I am trying to get the whole skin managed by a single row of buttons, like my Alpine head unit. Any examples you got would be great.
cheers master guru
KPJUK
M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
PHP Code:Single button to change the command for itself
“BYVAR;SETB1;PREV<<GPS<<GAMMA||BYVAR;SETB1;SETVAR;SETB1;1<<SETVAR;SETB1;2<<;SETVAR;SETB1;0”
Separate button to change command to anther button
Set button
“BYVAR;SETB1;SETVAR;SETB1;1<<SETVAR;SETB1;2<<;SETVAR;SETB1;0”
command button
“BYVAR;SETB1;PREV<<GPS<<GAMMA”
And if you want a text label for that button
“BYVAR;SETB1;Prev<<GPS<<Gamma”,"CENTER"
Also if you want it to save so when you restart RR
PHP Code:“BYVAR;SETB1;SETVAR;SETB1;1<<SETVAR;SETB1;2<<;SETVAR;SETB1;0||SAVETOINI;SETB1;$SETB1$”
Thanks Chuck,
I knew you were the man to help out, apologies for hi-jacking your thread !
I will give this a bat and see if I can get it going. I'll let you know
Cheers Bud,
KPJUK
Nice 1 mate,
I'm using the LOADIMG command to load small gif's for the Button "labels", and this is now working a treat, I just need to do the switchbuttons now and I'm sorted.
For reference for anyone else trying this, here is method used.
Button command set up in skin
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B01,3,0,99,66,"PREVTRACK","CENTER"
B02,101,-2,101,68,"FRWD","CENTER"
B03,199,-2,102,68,"PLAY","CENTER"
B04,300,-2,101,68,"STOP","CENTER"
B05,399,-2,102,68,"FFWD","CENTER"
B06,500,-2,103,68,"NEXTTRACK","CENTER"
B07,601,0,98,66,"OSK",""
B08,701,0,98,66,"MNUSwap",""
B99,687,548,114,49,"EXIT",Center
Button 8 is a custom command that is defined in Exectbl.ini as follows.
/, MenuSwap Commands
"M2B1","LOADIMG;14;8;75;50;M3-B1.gif;Out||LOADIMG;14;8;75;50;M3-B1.gif;Off||LOADIMG;14;8;75;50;M3-B1d.gif;Down||LOADIMG;14;8;75;50;M3-B1d.gif;On"
"M2B2","LOADIMG;114;8;75;50;M3-B2.gif;Out||LOADIMG;114;8;75;50;M3-B2.gif;Off||LOADIMG;114;8;75;50;M3-B2d.gif;Down||LOADIMG;114;8;75;50;M3-B2d.gif;On"
"M2B3","LOADIMG;214;8;75;50;M3-B3.gif;Out||LOADIMG;214;8;75;50;M3-B3.gif;Off||LOADIMG;214;8;75;50;M3-B3d.gif;Down||LOADIMG;214;8;75;50;M3-B3d.gif;On"
"M2B4","LOADIMG;314;8;75;50;M3-B4.gif;Out||LOADIMG;314;8;75;50;M3-B4.gif;Off||LOADIMG;314;8;75;50;M3-B4d.gif;Down||LOADIMG;314;8;75;50;M3-B4d.gif;On"
"M2B5","LOADIMG;414;8;75;50;M3-B5.gif;Out||LOADIMG;414;8;75;50;M3-B5.gif;Off||LOADIMG;414;8;75;50;M3-B5d.gif;Down||LOADIMG;414;8;75;50;M3-B5d.gif;On"
"M2B6","LOADIMG;514;8;75;50;M3-B6.gif;Out||LOADIMG;514;8;75;50;M3-B6.gif;Off||LOADIMG;514;8;75;50;M3-B6d.gif;Down||LOADIMG;514;8;75;50;M3-B6d.gif;On
"M2B8","LOADIMG;714;8;75;50;M3-B8.gif;Out||LOADIMG;714;8;75;50;M3-B8.gif;Off||LOADIMG;714;8;75;50;M3-B8d.gif;Down||LOADIMG;714;8;75;50;M3-B8d.gif;On"
"M1B1","LOADIMG;14;8;75;50;M2-B1.gif;Out||LOADIMG;14;8;75;50;M2-B1.gif;Off||LOADIMG;14;8;75;50;M2-B1d.gif;Down||LOADIMG;14;8;75;50;M2-B1d.gif;On"
"M1B2","LOADIMG;114;8;75;50;M2-B2.gif;Out||LOADIMG;114;8;75;50;M2-B2.gif;Off||LOADIMG;114;8;75;50;M2-B2d.gif;Down||LOADIMG;114;8;75;50;M2-B2d.gif;On"
"M1B3","LOADIMG;214;8;75;50;M2-B3.gif;Out||LOADIMG;214;8;75;50;M2-B3.gif;Off||LOADIMG;214;8;75;50;M2-B3d.gif;Down||LOADIMG;214;8;75;50;M2-B3d.gif;On"
"M1B4","LOADIMG;314;8;75;50;M2-B4.gif;Out||LOADIMG;314;8;75;50;M2-B4.gif;Off||LOADIMG;314;8;75;50;M2-B4d.gif;Down||LOADIMG;314;8;75;50;M2-B4d.gif;On"
"M1B5","LOADIMG;414;8;75;50;M2-B5.gif;Out||LOADIMG;414;8;75;50;M2-B5.gif;Off||LOADIMG;414;8;75;50;M2-B5d.gif;Down||LOADIMG;414;8;75;50;M2-B5d.gif;On"
"M1B6","LOADIMG;514;8;75;50;M2-B6.gif;Out||LOADIMG;514;8;75;50;M2-B6.gif;Off||LOADIMG;514;8;75;50;M2-B6d.gif;Down||LOADIMG;514;8;75;50;M2-B6d.gif;On"
"M1B8","LOADIMG;714;8;75;50;M2-B8.gif;Out||LOADIMG;714;8;75;50;M2-B8.gif;Off||LOADIMG;714;8;75;50;M2-B8d.gif;Down||LOADIMG;714;8;75;50;M2-B8d.gif;On"
"M0B1","LOADIMG;14;8;75;50;M1-B1.gif;Out||LOADIMG;14;8;75;50;M1-B1.gif;Off||LOADIMG;14;8;75;50;M1-B1d.gif;Down||LOADIMG;14;8;75;50;M1-B1d.gif;On"
"M0B2","LOADIMG;114;8;75;50;M1-B2.gif;Out||LOADIMG;114;8;75;50;M1-B2.gif;Off||LOADIMG;114;8;75;50;M1-B2d.gif;Down||LOADIMG;114;8;75;50;M1-B2d.gif;On"
"M0B3","LOADIMG;214;8;75;50;M1-B3.gif;Out||LOADIMG;214;8;75;50;M1-B3.gif;Off||LOADIMG;214;8;75;50;M1-B3d.gif;Down||LOADIMG;214;8;75;50;M1-B3d.gif;On"
"M0B4","LOADIMG;314;8;75;50;M1-B4.gif;Out||LOADIMG;314;8;75;50;M1-B4.gif;Off||LOADIMG;314;8;75;50;M1-B4d.gif;Down||LOADIMG;314;8;75;50;M1-B4d.gif;On"
"M0B5","LOADIMG;414;8;75;50;M1-B5.gif;Out||LOADIMG;414;8;75;50;M1-B5.gif;Off||LOADIMG;414;8;75;50;M1-B5d.gif;Down||LOADIMG;414;8;75;50;M1-B5d.gif;On"
"M0B6","LOADIMG;514;8;75;50;M1-B6.gif;Out||LOADIMG;514;8;75;50;M1-B6.gif;Off||LOADIMG;514;8;75;50;M1-B6d.gif;Down||LOADIMG;514;8;75;50;M1-B6d.gif;On"
"M0B8","LOADIMG;714;8;75;50;M1-B8.gif;Out||LOADIMG;714;8;75;50;M1-B8.gif;Off||LOADIMG;714;8;75;50;M1-B8d.gif;Down||LOADIMG;714;8;75;50;M1-B8d.gif;On"
"MNUSwap",“BYVAR;MenuSwap;MNU0<<MNU1<<MNU2||BYVAR; MenuSwap;SETVAR;MenuSwap;1<<SETVAR;MenuSwap;2<<SET VAR;MenuSwap;0”
"MNU2","M2B1||M2B1||M2B2||M2B3||M2B4||M2B5||M2B6|| M2B8||SETVAR;MenuSwap;0"
"MNU1","M1B1||M1B1||M1B2||M1B3||M1B4||M1B5||M1B6|| M1B8||SETVAR;MenuSwap;2"
"MNU0","M0B1||M0B1||M0B2||M0B3||M0B4||M0B5||M0B6|| M0B8||SETVAR;MenuSwap;1"
MNUSwap in turn runs three other custom commands. I set it up this way to be able to debug it easier.
These custom commands loadimages on top of each other, for each of the buttons, then resets the variable for the next time around.
I'll edit this post when I get the switchbuttons working !
Thanks again m8
KPJUK
