Page 11 of 33 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 330
Thread: Road Runner Installer and Updater (** Out Dated **)
  1. #101
    Low Bitrate leatherboy's Avatar
    Mar 2005
    Athens, Greece
    Thanks for the quick response. I dit run the installer. (no roadrunner.exe file created). I unzipped the updater in the root folder and I replaced the old RR_Updater.exe with the new. I run the rr_Updater.exe and I click the check your version button. Nothing happens.
  2. #102
    Mar 2005
    Athens, Greece
    I run it once more. And the message is RR Not Found
  3. #103
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    The updater still can't find roadrunner.exe. after you extract the binary into the roadrunner folder, and refresh the folder, to you still see the roadrunner.exe file? Before running the updater?
  4. #104
    Mar 2005
    Athens, Greece
    No, I downloaded 3 times the binary zip file. All the times when it tries to unzip the roadrunner.exe file I get the message tha the file is missing. I can see it in the file list of the binary zip but i cannot extract it right
  5. #105
    Mar 2005
    Athens, Greece
    Iget the message ie cannot receive this file from http://guino.home.insightbb.com when it reaches 99%. Can I get it from another mirror?
  6. #106
    Apr 2006
    Quote Originally Posted by leatherboy View Post
    Ok, If you're not able to extract the binary file correctly that's telling me there must still be something with your AV (or something... best I can figure...) that is killing it before it can extract the full archive to your RoadRunner folder. Make sure NOD has Advanced Huristics Detection turned off and if your Zone Alarm install has the AV portion running with it, make sure that's off as well.
  7. #107
    Apr 2006
    I just downloaded from that site, it finished 100%... something on your system is holding it back. It's killing roadrunner.exe inside the archive.
  8. #108
    Mar 2005
    Athens, Greece
    I ve once again with my AV disabled. I get the some message. I think i will try it from onother pc.
  9. #109
    Apr 2006
    Ok, good luck
  10. #110
    Mar 2005
    Athens, Greece
    what AV do you use? Or should I always work without AV if I want to run RR?
