Page 12 of 33 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 330
Thread: Road Runner Installer and Updater (** Out Dated **)
  1. #111
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by leatherboy View Post
    what AV do you use? Or should I always work without AV if I want to run RR?
    I use AVG and I know a lot of people on here do. You can use it with RR, but you have to turn off the Advanced Huristics Detection because it gives a lot of false positives and deletes the RoadRunner.exe file
  2. #112
    Low Bitrate leatherboy's Avatar
    Mar 2005
    Athens, Greece
    Thanks my friend. I will try it at home later.
  3. #113
    Apr 2006
    No problem and good luck. Hope you get it
    Cheers.
  4. #114
    Mar 2005
    Athens, Greece
    Hi again. It seems very strange but.... it is true. I 've tried to find this roadrunner.exe using 2 pcs without AV. I download the RoadRunnerBinary.zip.
    without problem. But when I extract it roadrunner.exe is missing. Can someone send it to me with an email or what else.
  5. #115
    Apr 2006
    Binary Version April 11,2007 - grab it here from SourceForge
  6. #116
    Mar 2005
    Athens, Greece
    FINALY. I did it . It is a great program. Thanks. And I already start to make plans for a skin. I have to find some hours to make it. Perhaps between 02 and 04 am. Thanks again.
  7. #117
    Apr 2006
    Good to hear. What was the final solution?
    Can't wait to see the skin
    Cheers... The W3bMa5t3r
  8. #118
    Feb 2007
    Quote Originally Posted by W3bMa5t3r View Post
    A lot of AV progrmams allow you to put in exclusions although you may have to still turn it off when installing programs. Check if you have an exclusions list.
    As fars as a good AV program I've been very happy with Avast. It's one of the best AV programs I've found, it has a small memory foot print, does not take a lot of overhead, gives you lot's of control and it's free for non-commerical use. You do have to reregister every 14 months.
  9. #119
    Jun 2007
    Sydney, OZ
    Hey guys
    I also had problems with roadrunner.exe not being present, turned advanced heuristics off in Nod32 and voila...bob's ur uncle!
    However when I run the updater it is able to verify which version of RR I have and is able to identify that a newer version is available but i get a "Download Failed" message. Any ideas????
  10. #120
    May 2005
    What is the latest version of roadrunner...
    It looks like I have version 1.0.0.0 (as indicated in the "version" tab when righ clicking the roadrunner exe and selecting properties.
    Thanks.
