Page 14 of 33 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 330
Thread: Road Runner Installer and Updater (** Out Dated **)
  1. #131
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by Wiredwrx View Post
    Me also.
    Michael
    2nd that
    i do a clean install and run the update and lose my road runner.exe, ive run the old version and the old updater, and its downloaded anad updated to the latest version according to the files.
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #132
    Feb 2007
    I had just tried to install the RR installer on my Window Vista Home basic. But it gives me an error when I tried to run RR from the desktop. The error is "Unexpected error: Quiiting".
    Can any1 help?
  3. #133
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by canopus88 View Post
    Can any1 help?
    So you got it installed, but you get the error when trying to run RR? Then you might want to pose the question in the main RR forum as this is just for the installer and updater (and I'm not really sure why you'd get that error trying to run RR...).
    Cheers.
  4. #134
    Feb 2007
    Quote Originally Posted by W3bMa5t3r View Post
    Cheers.
    I tried the binary file and it says failed to open...not too sure what is going wrong,..seems like I have to forgo Window Vista and use Win XP Pro instead.
  5. #135
    Feb 2007
    i tried to download the updater file from the first page - i get the famous "page cannot be displayed" error.
  6. #136
    Apr 2006
    Ok guys, the Installer has been updated and uploaded around the mirrors. There are two mirrors down so if you get a 404, just click on the download link again to hit a different mirror.
    Should be about 27MB vs the Older 24MB. I've included the new Zips / ZipLocator, MediaInfo Dll, Winamp Dll and Fmod dlls. Those that require registering should be at install.
    Cheers.
  7. #137
    Constant Bitrate will_santana's Avatar
    Mar 2007
    Rio de Janeiro/Brasil
    whatabout gdiplus? registering it won't do no harm
    and maybe a new option on the RR config to set the fastmode (i'd call the option something like "use transparences")...
    that would help a lot of RR new users and even old ones migrating to the new trasnparent skins
    []s
  8. #138
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    I am getting "Download Failed" on the Updater 2.0.0.2. Any clue why? I have no AV and Firewall is turned off, the system is 100% vulnerable
    Updater status find my version as 2007/09/05. I originally tried to run the updater and it killed my roadrunner.exe. So i updated the updater and got the exe from the DigitalFX installation because that is what i am running and put it in that directory.
    Should I just re-install the program from your installer?? Is your installer updated with the newest version? DigitalFX comes with the seperate RoadRunner.exe, is it necessary to overwrite roadrunner.exe again? or is that a question for JohnWBP?? thanks
  9. #139
    Apr 2006
    UMMM yeah well I forgot to update the file the updater looks to for the new file version. So it 'should' be good now.
    ALL RR HOSTING PROVIDERS.
    I've created a new Mirror Management System at http://w3bma5t3r.com/mirror/
    if you're currently hosting the RR Installer and Updater, or would like to, please sign up there. You can create an account and then add/modify/delete hosted packages, set daily download limits etc. This also allows you to disable downloads if needed for a period of time.
    If you're already hosting files, since your links/packages are already added in, once you create an account I can update your links so they appear in your management area.
  10. #140
    FLAC djmickyg's Avatar
    Feb 2004
    The updater is finally working for me!! on both my desktop and carpc.. !
