Page 15 of 33 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 330
Thread: Road Runner Installer and Updater (** Out Dated **)
  1. #141
    Dec 2006
    Issue with selecting Radioshark
    When you select Radioshark it defaults back to HQCT when you access the RR Config.
    BTW, is RR Config supposed to replace RRConfig.
  2. #142
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by Firebird2 View Post
    You'll probably want to ask that question in the Release thread, as I just build the installer and updater.
    Looking at the dates of the files, yes, RR Config has replaced RRConfig.
  3. #143
    Apr 2006
    Updated installer has been distributed to all the mirrors (those reachable). Includes the RR Help file from KPJUK.
  4. #144
    Mar 2006
    Colorado, but Canadian!
    Hola. Nice job on these. I havent updated my RR since the version before April 2006, but today I am doing a full on reinstall (2.5" lappy drive failed friday). Awesome work!
    I used the installer to setup RR, and I expected much more hassle, much more manual work. But It really was click a button and done. Thanks to you guys there is absolutely 100% no reason why people should shy away from RR because of its un-n00by installation.
    Anyways, the reason I am posting is because I know the 9/9/07 version is out now, and the installer is outdated, so I used the installer then the updater. I realize that you have the "run from root RR folder" on the top of the updater, but honestly, I dont read what I click, so I ran it from my thumbdrive. It detected RR, said there was a new update, downloaded it to a zip file I believe called "NewRRSomething" and then it errored out with a "run from root", so I saw the sign and went "Doh!" Interestingly enough the updater gave me a "doh" messagebox too.
    Anyways again, it got far enough in updating to delete completely (not in Recycle Bin) the RR.exe file but did not replace it with anything! I am not sure if you are aware of this or if this is an isolated event. But perhaps change the checking of the root folder to before it deletes the old exe. It was no biggy, as I just ran the easy-peasy installer again and all is good. But might be something to improve on.
    Great job guys!
    1.9in x 2.9in -- 47mm x 73mm
  5. #145
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    Quote Originally Posted by W3bMa5t3r View Post
    Looks like it's now back to RRconfig.exe again! Didn't see it mentioned specifically, so is RRconfig updated by RRupdater?
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
  6. #146
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    NO! The config has its own builtin updater...as there are more updates to the config still that some people wouldn't know about until the next RR release...
    Current config ver is 1.0.0.2
    And just to make it more confusing, I decided to change the name of mine to the old name of 'RRConfig.exe' to lessen the hassle of these kinda problems...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #147
    Nov 2006
    RRUpdater and 9/30/2007 version of RR
    RR_Updater tells me that my RR is at the 9/9/2007 level and that it is up to date but there is a 9/30/2007 version.
    Is there a problem or is there a new updater version for th 9/30/2007 version of RR?
    Regards,
    Jim
  8. #148
    Mar 2006
    Quote Originally Posted by obrienj View Post
    Regards,
    Jim
    The update server needs to be updated.
    webmaster I think runs it and he is MIA right now. Just download the binary, and replace what is in the folder (overwrite).
  9. #149
    Newbie Tups's Avatar
    Sep 2005
    sorry
  10. #150
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    wrong area to post problems with rr
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
