Page 18 of 33 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 330
Thread: Road Runner Installer and Updater (** Out Dated **)
  1. #171
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by VettePC View Post
    This is very difficult for a newbie to install. The "guide" is NOT a very good thing to use..IE; states to use Winamp 2.95.. Is that a good idea?
    Is there someone in the know that could do a simple Quickstart guide for a newcomer here. I have spent a week so far trying to get this to work with The DigitalFX skin. Almost got there and then things degraded quickly.
    Now, I have uninstalled RR and DELETED the RR folder. Ran the installer, then DigitalFX.... ran the RRConfig, to set Winamps path, my GPS COM port, Pic path etc. When I start RR it runs great.. music plays, GPS STATS work, Iguidance works, then FREEZE. No matter what I operate after starting RR it freezes.
    Any idea on what to do next?
    What are the BASIC steps to install a fresh start of RR???
    Create a directory called Road Runner in Program Files and then unzip the binaries into it?
    Then run RRConfig.exe?
    Help!
    Your best bet is to:
    1. Run the RR installer.
    2. Go into RR folder and delete the file "ziplocator.dll"
    3. DL a current copy of the rr binary and drop the roadrunner.exe in the folder.
    4. DL the current config ver (see my sig)
    5. Run the RRConfig.exe.
    That should get you started...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #172
    Low Bitrate VettePC's Avatar
    Dec 2007
    Thanks... I have been working on a RR install that seems to be getting there... s l o w l y...
    So , where is the best pace to get the newest RR installer?
    Here: http://www.w3bma5t3r.com/mirror/dopp...kage=Installer ??
    What does "ziplocator.dll" do? I dont have it in my current setup.
    I am afraid of trying a different rrconfig.exe. I think that is what screwed up a good start I had going at one point. I am using one that is probably 3 months old... 254K file
    Maybe you know.. IF I wanted to try testing say your new RRConfig.exe (or any other experiment) -- Can I just copy the entire folder (Program Files\Road Runner\ and if all goes haywire, just copy the backup back? Are there any other changes made to the system? IE; registry changes, etc?
    I have been working on weird things today, like :
    Audio_Playlist.skin ::
    Vol- button loads the "MIXER" skin
    Vol+ button loads GPS!
    I have found several other skins that are incorrect (DFX2.5)
    Makes me wonder.....
  3. #173
    _
    Mar 2004
    Little Elm, Texas
    So is the installer and updater working now? I see above where some folks mention that it's not working but that was about a month ago...
    Jan Bennett
  4. #174
    Dec 2007
    Quote Originally Posted by RedGTiVR6 View Post
    So, do other people have this happening?
    Go to MUSIC then PLAYLIST button, then VOL- ==> loads MIXER screen
    VOL+ ==> loads GPS
    I also have several other buttons that are wrong...
    Just curious if anyone else's RR + DFX2.5 does this?
  5. #175
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    There were some probs with DFX2.5, and it has been mentioned in that thread. There is DFX 3.0 just around the corner...
    Drop these in your dfx folder, should take care of those buttons
    Attached Files Attached Files
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #176
    Dec 2007
    Oh,ok, sorry if I missed that post. Thanks for the fix file, I had already fixed the play list skin, but had'nt found the problems in the audio_search.skin.
    Also there are 3 more errors in the Audio_search.skin (in my skin anyway):
    PREV BUTTON:
    IS:
    B16,199,520,97,78,"LOAD;Audio_Browser.skin","Playl ist"
    CHANGE TO:
    B16,199,520,97,78,"PREVTRACK",
    PLAY/PAUSE BUTTON:
    IS:
    B,299,520,96,78,"LOAD;Audio_Player.skin",
    CHANGE TO:
    B,299,520,96,78,"PLAY",@STOP||PLAY@
    NEXT BUTTON:
    IS:
    B10,398,520,98,78,"PLAY",@STOP||PLAY@
    CHANGE TO:
    B10,398,520,98,78,"NEXTTRACK",
    Also there are many errors in my XM_Favorites.skin :
    POWER ==> scans
    IS:
    B07,103,510,96,89,"SCANMODE","Scan"
    CHANGE TO:
    B07,103,510,96,89,"EXITMENU",""
    PLAY/PAUSE ==> scanS
    IS:
    B06,297,510,101,89,"PLAY","Play" --Acts like scan
    ..........TRIED THE FOLLOWING:
    B06,297,510,101,89,"PLAY",@STOP||PLAY@ -- SCANS ?
    B06,297,510,101,89,"PLAY", -- SCANS!?
    I SET IT TO: (FOR NOW)
    B06,297,510,101,89,"EXIT","Exit" - RETURN TO PREVIOUS WINDOW
    PREV ==> loads Mixer window
    IS:
    B04,200,510,96,89,"MIXER","Mixer"
    CHANGE TO:
    B04,200,510,96,89,"PREV",
    NEXT ==> loads GPS window
    IS:
    B20,398,510,101,89,"GPS",""
    CHANGE TO:
    B20,398,510,101,89,"NEXT",
    Sorry for the long post... Just thought you would like to know in case the 3.0 has the same problems...
    Oops,, should this be posted in the DFX forum so others will be aware of these things?
  7. #177
    Dec 2007
    Gonzales,LA
    At the end of installtion i get
    Road runner has not been installed becaus eof the followin reason
    Cinergy\Radio_IO.dll this files contains invalid data
    what gives????????????????????
  8. #178
    Dec 2007
    Quote Originally Posted by chvybeatsford View Post
    I would uninstall RR, and delete your downloaded RR installer if thats what you used, then download another copy of RR. You might have a corrupt download...
  9. #179
    Dec 2007
    Gonzales,LA
    Well that seemed to work.Very nice setup here thanks.
  10. #180
    Dec 2007
    okay i am having a real issue getting my music and videos to play, it opens win amp in a separate window but that wont play my mp3s or videos.
