There is still a bug with the 2.0.0.2 updater. It continues to say there is an update available, but when I click download it responds with "Download Failure" errors.
If there is an update available, where can I download it from?
I am having the exact same problem as andrea here. When i had MapMonkey 1.1.344 and RR 2.0.0.12 it worked fine, but i have updated MapMonkey to 1.1.387 for the quick voice mute button and it no longer works by clicking on the GPS button. I updated RR to 2.0.0.24 and there was no luck. i can run MM on its own fine, or select it as external GPS program, but then I cant use the RR media controls at the bottom of the GPS Screen and it shows the stupid XP window round MM.
should i try to fix the MM command or leave it as an external app and embed the window?
thanks in advance
(sorry if this is in the wrong place aswell)
ware_10![]()
Try installing RR again without the updater...I'm not using the new updater, and I don't have any problems what so ever updating RR.![]()
Pardon me for my ignorance.. why bother updating... With new RR install, it works flawless... Is it because of new plugins?
It's to make RR more user friendly...
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
thanks for ur work Blue... new installer works great... I have a question though.. i tried gasfinder and it didn't work... I even copied over the binary.. didn't work.. maybe i do need to run updater after all... I noticed some files were missing from the newer version. Is my new installer didn't complete it all the way or are you guys doing some cleaning job or Guino is? Other than everything looks great so far...
I can't really say too much on the whole installer...as I don't use it. Its really all part of making the RR easier to install and start using...
Its most good for new comers to RR and need something that they can just run, just like a typical installation of any program...
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
my antivirus found something in the rr_install.exe file... is it just me or somone else had same problem?
1.9in x 2.9in -- 47mm x 73mm
