Page 29 of 33 FirstFirst ... 192021222324252627282930313233 LastLast
Results 281 to 290 of 330
Thread: Road Runner Installer and Updater (** Out Dated **)
  1. #281
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Quote Originally Posted by notion View Post
    I was under the impression the updater was a much smaller file rather than the full installer.
    The updater is a much smaller file, but alot of folk have had issues getting it to work correctly. One of these days I'll rerelease a (hopefully) better version.
  2. #282
    Jul 2008
    hi, i downloaded 4 times from 4 different mirrors,tried to install each one by one and i keep getting error messages stating ----- C:\Program Files\RoadRunner\SKINS\Alpine\does not contain a valid skin! check your settings and try again.----- what the hell is going on here .what alpine skin?I installed RR dozens of times on differant machines with no problems.All of sudden i get this??? is there something wrong with all download mirrors? also i tried to download standalone updater and all i get is no file?can someone help me get back on track. thank you.
    me also
  3. #283
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    current installer has a space in road runner install directory
    eg will probably be installed to...
    C:\Program Files\Road Runner\SKINS
  4. #284
    Apr 2005
    I just ran the updater and it worked.
    Most everythign works, but when I click on music
    it doe snot play my mp3's (and the config is pointing to the right directory C:/MP3s)
    when I click on the play list
    the next screen does in fact showmy play list, but in the playlist symbol on the right in the middle of the up and down triangles there is a RED X over it....
    clicking on any of the songs does nothing
    any ideas?
  5. #285
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by blackcar View Post
    any ideas?
    Did you make sure to select mp3 as a music file extension in RRConfig?
    1.9in x 2.9in -- 47mm x 73mm
  6. #286
    Apr 2005
    Quote Originally Posted by 2k1Toaster View Post
    yeap, still it still doesn't work
  7. #287
    Apr 2005
    Here are some of my screen shots
    mp3 format is selected, I've tried both ".mp3" and "mp3"
    my main music screen
    and what I see when I click on the list icon
  8. #288
    Mar 2006
    Try adding those songs you see to your now playing...
    Click +1 to just add the song, or the next one over to add all of them and replace what you have playing, or click the next one to just add to what you have. Then click the bottom right arrow to return and there you can play/pause/stop/whatever the music.
  9. #289
    Apr 2005
    yeap , I tried the +1 and the 2 other ones on the same row (down arrow into basket)
    but it didn't do anything
    oddly on that same screen the "list" icon on the right has a red "X" on it
    I don't think I've see that before....
    my videos (sound works fine) and navigation work just fine, just dunno why music is out...
    somehow it's not RR is not seeing the list or the files.
    from memory I recall the 1st music page should show "/MP3"
    but now it only shows "/" along the top.
    Not sure why that is, because the path is specified correctly on the config page
  10. #290
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The red X has always been there, it means clear list (delete list)
    Also you are using the old RRConfig, there is a newer one
    RR Config Updated - Blue ZX3
    download and try that. (I suspect you don't have the winamp dll registered, the New config will do that for you.
