Page 9 of 33 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 330
Thread: Road Runner Installer and Updater (** Out Dated **)
  1. #81
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    "Demo" is the name of the track that Winamp is playing. The track name shows up on the top of the screen in the BMV2 skin, and by default, the first time you run Winamp, it loads a track into the playlist called "Demo." It just so happens that the way the skin is designed, it looks like you're actually running a Demo of RR.
  2. #82
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by Nola111 View Post
  3. #83
    Dec 2006
    fm radio
    Anyone in here using RR and what fm radio setup are you using it and what is the best fm radio for RR and why does change back to default on mine.
  4. #84
    Apr 2005
    Queens, New York
    Quote Originally Posted by GADGETMAN View Post
    Wrong section to be posting check out here:
    http://www.mp3car.com/vbulletin/hardware-development/
    and here:
    http://www.mp3car.com/vbulletin/gene...re-discussion/
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  5. #85
    Apr 2006
    The updater is good to go for the new version... just run it. I've noticed that it might say the update is unsuccessful, even though it is good... so do the update and if you're worried about it, check the file modification date of the new RoadRunner.exe... if it's 4/11/2007 you're good to go. I'll be releasing the Updated Installer sometime in the morning.
    Later... The W3bMa5t3r
    /edit... on a side note, this thread only has a 4.33 rating? how sad...
  6. #86
    Mar 2007
    How does the updater work? download the file then hit update or just hit update and it searches for an updated version?
  7. #87
    Apr 2006
    Quote Originally Posted by davidingermany View Post
    Just run the updater. It'll determine if you need to update and prompt you to do so. If so, it'll download and extract for you.
  8. #88
    Jan 2007
    Columbus, OH
    Okay, I thought it was something up with my system after it got done extracting and came back unsuccessful. I'll have to check the version date later. I'm looking foward to the new updater whenever it is released.
  9. #89
    Apr 2006
    New Updater has been released and uploaded. The updater version is 2.0.0.0, so if you're unsure if you have the most recent version or not, check the file properties of the updater and check it out.
    NOTE: There is now only ONE version, it is has a larger GUI so it's useful for both normal and touchscreen monitor usage.
    This is a rewrite of the program, so please let me know if you encounter any issues.
  10. #90
    Nov 2006
    Whenever I hit "Check your version" button, It saying "RR Not Found". Please advise.
