Results 1 to 5 of 5
Thread: Loading a saved Playlist
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Question Loading a saved Playlist
    Ok, I have searched extensively (using this board, and google's Site search feature, the Skin commands.txt ect ect....), and can't seem to find what I am looking for.
    I want to simply have a button to load a saved playlist. NOT a hardcoded button, with the name of the playlist in the buttons code.
    Such as:
    Code:
    "LOADROCK","RUNQ;<Path>\Winamp.exe <Path>\Rock.m3u||RELOADLIST"
    I am looking to press a button to go to either another screen/pop-up menu(prefered) showing the contents of the playlist directory (as configured in the RR.ini), and select one from it.
    I just can't figgure out how to browse to the defined directory in the RR.ini when pressing a button, and have the playlists that are saved displayed to choose from.
    I have seen lots of workarounds to load playlists such as pressing a button up to 5 times for different playlists, and a menu that chuck designed to press an icon to load a certain defined playlist.
    It seems quite odd to me that you can press a button and the OSK pops up to allow you to input a name of the playlist and save it, but not be able to do anything to load it, other than hardcoding the playlist name on a buttons code.
    My Fiero Build Thread
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    what i do is create a folder inside my music lib (mine is named -{saved list}-) and this is where i save all my playlist.
    When your inside the audio browser just go into the folder where the playlist are and load them.
    I named the -{saved list}- like this so its allways at the top of the list so i dont have to search for it.
    beer replenishment fund
    mp3car live search
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can do exactly what you want though, make a popup screen with a Folder list in it, and use the SD definition to define where it will be showing files from. Then just use the MENU command to display it, up/down to scroll and the SELECT command to load it.. I am pretty sure a few users have done that already.
    Ride Runner RR's Myspace
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Hello John,
    Download this skin Black Vinyl on Aluminium
    Press the bottom right menu button to get to the main menu,
    Select top left button marked MP3 to get the audio Player menu
    In the centre of the screen is The button to get to the Audio Browser screen.
    On the right in the Playlist section are three buttons to load, save and clear Playlists.
    To get the load option working for your config, you need to make sure that you have the SD entry in the Plist.skin set to point to the directory of your saved playlists, or to the variable $playlistpath$, like this
    MEDIACAR Skin
    MEDIACAR Black Vinyl on Aluminium Skin
    /, SD, Alignment;Alignment, Disp;MODE, Icon Width, Icon Heigth, Path
    SD,oo,"00",,,"$playlistpath$"
    /, S, x, y, w, h, fore R;RGB, G, B, back R;RGB, G, B, folder R;RGB, G, B, file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, font name
    S01,15,52,232,262,0,255,0,,,,255,255,255,,,,128,0, 0,255,255,128,,16,"Arial:B"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,15,15,230,33,149,149,0,20,"Arial:B","=Playlist s","CENTER"
    L02,21,355,98,42,255,255,0,20,"Arial:B","=Load","C ENTER"
    L02,145,355,98,42,255,255,0,20,"Arial:B","=Cancel" ,"CENTER"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,4,331,127,80,"SELECT||EXIT",
    B02,131,331,130,81,"EXIT",
    END
    If this is the sort of thing you want to do, hack the skin commands to suit your requirements.
    Good Luck
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Thanks Guys!
    guino, as always thats for the quick reply and a sollution!
    Thanks Kpjuk for the sample code! I appreceiate it, I just couldnt seem to get it to work here.
    Thanks guys!
  1. How About...A Virtual CD Changer
    By chuckster in forum Road Runner
    Last Post: 09-23-2011, 02:03 PM
  2. EniCar the RR Clone
    By enitalp in forum Software & Software Development
    Last Post: 12-13-2008, 05:12 PM
  3. Playlist and save bugs
    By tolisn in forum RR Bug Tracker
    Last Post: 04-04-2005, 11:16 PM
  4. irman isn't loading any playlist
    By peter3 in forum Software & Software Development
    Last Post: 02-11-2001, 09:59 AM
