Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: lil help with iguidance 3
  1. #21
    Apr 2006
    Thanks alot guys it worked. all i did was what u told to me. clear the comm in rr and it started working.
  2. #22
    Mar 2007
    Nashua, NH
    I know this thread has been idle for a while now, but I came across some info that may be worthy of the archives.
    I had problems running RR with the DigitalFX skin and having RR show the compass and speedo while getting the nav system to work. I originally had rr.ini and iGuidanceUMPS pointing to the same com port (com4). Then I installed xport3 and (here's my big mistake) set com4 to split into com10 and com11. I chose 10 and 11 just to keep things clear.
    Upon starting iGuidance or iGuidanceUMPC, they immediately reset the com port in the registry to 1. This is true if it's running within rr or not. So I tried setting xport to creating ports 5 and 6 and now iGuidance does not reset the com port to 1...and everything is working!
    For some reason iGuidance can only handle com ports up to a certain number.
  3. #23
    Constant Bitrate DJKhan85's Avatar
    May 2004
    Boston, Mass
    Quote Originally Posted by meisner View Post
    Your timing on this is so close to what I just dealt with its scary. I ran into this yesterday using com ports 10 and 11. I've since switched to ports 5 and 6 and all has been good.
    Computer:
    COMPLETE SYSTEM OVERHAUL!!!!!!
    STAY TUNED IN THE UPCOMING WEEKS!
  1. Replies: 570
    Last Post: 11-05-2009, 02:49 PM
  2. Replies: 17
    Last Post: 06-15-2006, 12:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 06:21 PM
  4. Hacking Iguidance
    By Peoples in forum GPS
    Last Post: 08-28-2005, 06:40 PM
  5. Replies: 2
    Last Post: 08-18-2005, 11:15 PM
