What skin are you using? You may want to check the .skin file to see if it is closing iguidance or loading the menu screen.
It should look something like this:
Obviously it should hace the proper coordinates and such. You can use rrskineditor to make it easier if you aren't familiar with the skin code.Code:B03,676,1,122,54,"LOAD;MENU.skin",
LinkBack URL
About LinkBacks
