Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 47
Thread: Draft RR Help file
  1. #11
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Thanks W3bMa5t3r,
    First blood to you !
    I have included the installshield installation and a new page for the installshield updater, which will be released in v005. I agree we need to get this file included in the installshield and RR releases, so we need to tie this up with Guino to find out his release plans.
    cheers
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
  2. #12
    Mar 2004
    Stockholm, Sweden
    Quote Originally Posted by 65coupei6 View Post
    It doesn't seem to work for me. All I get is page not found in the help window.
    Same for me, tried it on two different computers...
  3. #13
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    ok, I'll host the 004 version too..
    http://www.w3bma5t3r.com/rr/RRhelpv004.chm
    I'll do the other versions as well as they come out...
  4. #14
    Dec 2003
    West Midlands
    The only reason I can think of is that chm's can be potentially dangerous files, so your PC might be blocking it. I will start to zip the files and see if that helps.
    Check out the first post.
    Thanks for the hosting W3bMa5t3r, I have made those changes to the installer, and they are now included in v005, I have also zipped the file to see if that helps users to download.
    cheers
    KPJUK
  5. #15
    Apr 2006
    Washington, DC
    Added the v005 to the install package and updated the first post stating I've added your RR help file to the package. Just let me know when you release the new versions and I'll update the package. Cheers
  6. #16
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    THe newest version of RR is 09-07-06, I have this installed. I tried the updater and it shows that 09-05-06 is the newest. I know that 05 had some critical changes. Any chance of updating the installer and the updater..?
    thanks in advance
    and great job
    New Age Garmin - Skin for RR
  7. #17
    Apr 2006
    Washington, DC
    Quote Originally Posted by ThunderStick View Post
    thanks in advance
    and great job
    Unless you're talking about a beta version, the last version (just now to verify) I've downloaded shows 09-05-06 being the newest, which is what is packaged in the installer and what the updater is set to download/install. I've built the updater to install only the normal binary release (the one Guino stickys). Beta installs are on those who choose to use... ;-)
  8. #18
    Constant Bitrate deus ex machina's Avatar
    Mar 2006
    Under "Installation," the section that should be titled "Upgrading Road Runner" is "untitled."
    Also, when you upgrade RoadRunner, it's only necessary to replace rr.exe and RRConfig.exe (updating Skin Commands.txt and readme.txt is not necessary but advisable). Overwriting the entire RR directory will result in loss of all changes and customizations (most of which being in the ExecTBL.ini).
  9. #19
    Dec 2003
    West Midlands
    Thanks deus ex machina,
    some of the info in this file has been copied from stickies, and other posts. That is why I need the edit checks from you guys in the community. I am suffering from "can't see the wood for the trees" syndrome, so top marks for spotting those mistakes, they have now both been included for the next release.
    cheers
    KPJUK
  10. #20
    Aug 2005
    San Francisco
    I don't know what I did but it works now
  1. LSX (VOID) released
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 03-01-2007, 11:43 PM
  2. FAT16 FIle creation problem
    By sachin_athanika in forum Win 9x Based
    Last Post: 05-08-2006, 02:57 AM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  4. Editing XM playlists in RR
    By mbayers in forum Road Runner
    Last Post: 08-30-2005, 04:44 PM
  5. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 02:21 PM
