Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
Thread: Draft RR Help file
  1. #21
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Thanks for the input guys, and please keep it coming.
    v006 is now ready for download
    RRHelpv006.zip
    cheers
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
  2. #22
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    In the RR INI section, more ini settings
    GPS speed volume!
    see post:
    Setvol and Speed Attenuated Volume Control
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #23
    Dec 2003
    West Midlands
    Talking
    Thanks Blue ZX3,
    I need to get a better definition of the rr.ini section. If I am confused others will be too.
    speedatt=true (When you want to use auto volume)
    speedattmute=true (Toggles manual mute auto)
    speedattunit=mph (set this for miles or kilometers)
    speedattgrad=40 ( ? Guino maid know)
    speedattvola=10 (The start volume level)
    speedattvolb=25 (The max volume level)
    speedattspeeda=0 (When to start auto volume, at 0 Mph)
    speedattspeedb=75 (When to stop auto volume, at 75 Mph)
    speedattmode=line (Linear I think)
    speedattvolzero=70 (? Guin maid know)
    speedattvolgainat50mph=5 (Raises the volume 5% at 50Mph)
    speedattmaxstep=10 (Increments between min and max volume)
    Can anyone else help ?
    I am also looking for help definitions for the Road Runner Tools section. If anyone has anything that can be added please PM me or post information here.
    cheers
    KPJUK
  4. #24
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    GPS speed volume!
    see post:
    Correct me if I am wrong.
    A lot of those code from that thread never get merge with the main code that guino release. Guino, can you con firm this?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  5. #25
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, it is in the current code, I was using it with the last ver....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #26
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    More rr.ini settings
    From post:
    GPS Gamma support
    Description: This introduces a new Gamma Mode (3) which when set will make use of the GPS data from rr's gps port
    to set the day or night gamma.
    gammamode=0|1|2|3
    This will tell the software to use Gamma Panel (1) or GammaControl (0) with the GAMMA button(s).
    Now also possible to use (2) for Built in gamma loaded from the general.ini file of each skin.
    Now also possible to use (3) for Built in GPS gamma control
    GPSGammaModeOffset= (mins/2)
    Value is in minutes and enables the changing of the Gamma to happen gradually over a period of time.
    E.g. if set to 30 mins will cause Gamma to change between day and night over a period of 60 mins.
    autogammamode=0|1|2
    (0) Auto Gamma Changew/o user interaction
    (1) Auto Gamma change with 3 state gamma button Day|Night|Auto
    (2) Auto Gamma change disabled
    autoskinmode=0|1|2
    (0) Auto Skin Changew/o user interaction
    (1) Auto Skin change with 3 state Skin button Day|Night|Auto
    (2) Auto Skin change disabled
    gammaday=0:0:0
    -+Red : -+Green : -+Blue
    Day Gamma settings for Auto change gamma
    gammanight=-65:-65:-65
    Night Gamma settings for Auto change gamma
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #27
    Dec 2003
    West Midlands
    Thanks Blue,
    I will add this to the next version
    KPJUK
  8. #28
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I think I took out the gammaday= and gammanight= settings at some point (or at least disabled them). They were rendering useless the settings in the skin's general.ini regardless of the settings being provided or not.
    Ride Runner RR's Myspace
  9. #29
    Dec 2003
    West Midlands
    Thanks Guino, what about the others ?
    KPJUK
  10. #30
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the others should work. But I'm pretty sure they work over the GPS information.
  1. LSX (VOID) released
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 03-01-2007, 10:43 PM
  2. FAT16 FIle creation problem
    By sachin_athanika in forum Win 9x Based
    Last Post: 05-08-2006, 01:57 AM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  4. Editing XM playlists in RR
    By mbayers in forum Road Runner
    Last Post: 08-30-2005, 03:44 PM
  5. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 01:21 PM
