Page 5 of 5 FirstFirst 12345
Results 41 to 47 of 47
Thread: Draft RR Help file
  1. #41
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Quote Originally Posted by W3bMa5t3r View Post
    Hey bro, do you have an upcoming release?
    Cheers,
    The W3bMa5t3r...
    Hello m8,
    after two weeks of being sent 3 wrong adapters to charge my Laptop, the right one has finally arrived, but I am backed up at the moment. I will be doing an update sometime through this week, if I can get the time. I will PM you update as soon as its done.
    cheers
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
  2. #42
    Dec 2003
    West Midlands
    Smile Looking for Help File Contributions
    I am hoping to issue the next update of the Help file this week. If you have any contributions to make, I can include them in this release. Either post the content here, or PM me.
    cheers
    KPJUK
  3. #43
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    kpjuk, the following may be on the next release of RoadRunner.
    iG Auto switching to GPS on Guidance and/or Voice integration with RoadRunner.
    RR.ini setting
    *** All ini setting can be change at run time by using SETVAR****
    Example: "SETVAR;lastscreenswitchtime;15" or "SETVAR;pauseonvoice;false"
    igautosw=true|false
    This tell RR to automatically switch to GPS screen execute IGAUTOGPS command which is a custom command for GPS.
    Set to true (default), will auto switch when Guidance screen come up. Also modified IGAUTOGPS to your need.
    This is the setting that enable/disable the feature. Run time change can be accomplished by using SETVAR;igautosw;true|false
    gpsonvoice=true|false
    Set to true (default), will auto switch when iGuidance given voice direction. This setting is ignore if igautosw is set to false.
    pauseonvoice=true|false
    This tell RR to automatically pause/resume current player by execute IGPAUSE/IGRESUME commands which is a custom command for PAUSE/RESUME.
    Set to false (default), will NOT pause/resume current player. This setting is ignore if igautosw is set to false.
    lastscreenswitchtime=[0-30] in seconds.
    This tell RR to automatically switch to GPS screen execute IGAUTOGPSEXIT command which is a custom command for LASTSCR.
    Set to < 5 (default = 0), will NOT auto switch when Guidance close or iG finished given voice direction. This setting is ignore if igautosw is set to false.
    Commands: These command can be change to suit your needs via ExecTBL.ini
    IGAUTOGPS: Default it will execute GPS on voice direction and detection of Guidance screen. Change it to whatever command you like.
    One thing is that if you have full GPS skin, it a good candidate for loading that skin.
    IGAUTOGPSEXIT : Default will execute LASTSCR command. Change it to load any other skin instead of Last screen.
    IGPAUSE: Default will execute PAUSE command. Change it to suit other player that doesn't pause with PAUSE command.
    IGRESUME: Default will execute RESUME command. Change it to suit your need.
    Indicator:
    IGIND: ON when iG is in Guidance mode OR voice direction OR both.
    This thread has all discussion about it.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  4. #44
    Dec 2003
    West Midlands
    Quote Originally Posted by MatrixPC View Post
    RR.ini setting
    igautosw=true|false
    Indicator:
    Thanks MatrixPC,
    I will add anyway, and if the next release is so soon, I will issue it at the weekend, please let me know, and thanks for your support.
    cheers
    KPJUK
  5. #45
    Dec 2008
    The download link was broken
  6. #46
    Dec 2003
    West Midlands
    Quote Originally Posted by efun View Post
    My God, I thought this link was well and truly dead lol. I moved the files as part of a tidy up a couple months ago. I have updated the link in the first post. The last updates I made to the help file was 2nd November 2007.
    cheers
    KPJUK
  7. #47
    Dec 2008
    Just download it, great work!
  1. LSX (VOID) released
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 03-01-2007, 11:43 PM
  2. FAT16 FIle creation problem
    By sachin_athanika in forum Win 9x Based
    Last Post: 05-08-2006, 02:57 AM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  4. Editing XM playlists in RR
    By mbayers in forum Road Runner
    Last Post: 08-30-2005, 04:44 PM
  5. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 02:21 PM
