Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 59
Thread: Embedding SLingbox
  1. #21
    Aug 2006
    Reston VA
    [QUOTE=GizmoQ;931369]Can you go back to them and have them pricematch?
    That's a great price. I was actually thinking about getting a second one. I'll pass the info along to my friends as well.
    Personally I've gotten about $1000 dollars worth of smiles from friends and family who have seen the setup. I also bought my Slingbox with mostly Reward Zone Dollars from Best Buy.
  2. #22
    Feb 2005
    I love my slingbox, it has worked very well for me over my slow connections here in Kuwait. I run over satellite that is super sketchy, when I run speed tests it shows that I am just over dial up speeds. I would love for this to embed into my RoadRunner software!
    Brent
    1999 Nissan SE-L - turbo toy
    1993 Nissan NX - Turbo Racer
    Standalone fuel management (AEM EMS) on both
    carPC
  3. #23
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    For those already with a home PC with a tuner card, Orb is a solution. There is also a plugin for Winamp.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  4. #24
    Dec 2005
    Quote Originally Posted by DaveDog View Post
    ok, but for those of us with slingbox.
    I have verizon EVDO, and it rox wiht sling, i just cant embed. Has anyone been able to embed this app into rr yet?
    thanks,
    sideone
  5. #25
    Jun 2006
    Slingbox embedding.... ? - Hints?
    Guys - I took the plunge too after a year+ waiting and see on this product but bought it "mainly for CarPC"...
    Sadly in 2 pages of this thread I did not find any hints or tricks to RR Embed?
    I am trying to find the right window grab with Winspector - can anyone offer some input and suggestions for a solid tie-in. This is a KILLER concept for the car even if you need to turn quality way-down and News, Sports, or other is what you want to catch up on....
    Please advise if anyone found the proper Text / Class combo - I am digging thru just not found it yet and would prefer it RR embedded if at all possible.
    Thanks....
  6. #26
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    I used SKINbedder to crop SlingPlayer to just the video window (after loading Sling with the videowindowonly skin). Then I made 2 RRSkins to embed "SKINbedder - SlingFreedom" (Sling.skin with control buttons and Slingfull.skin for full-screen video). I had to make the second skin because if you just tell Sling to go fullscreen SKINbedder/RR pops it back into the embedded window right away.
    My one issue is that I cannot have Slingfull.skin be completely full screen because I need a button to go back to the normal skin. Does anyone have a way to make a 800x600 transparent button on top of the video window?
  7. #27
    Jun 2006
    RPM -
    Can you advise what Class or Name you were able to use to grab the SlingBox Video window into Skinbedder.... I am working it now and seem to be having issues with what it will pull to then crop.
    Thanks for your helpful assist sir...
    Quote Originally Posted by RPM_VR4 View Post
  8. #28
    Nov 2004
    L.A.
    I don't remember. It is easily discoverable with the Auto-It window tool.
  9. #29
    Jun 2006
    Embedding SlingBox
    RPM -
    I've been on this over 4 hours with Winspector and the AutoIt tool and simply can't find the Name nor Class that will grab... The closest I can get is the Class of CFrameXXX which will pull the Remote Control only ---- I am losing my marbles on this one and usually can find ClassNames and embed pretty easy - this one is clearly tricky....
    If you could just tell me what seemed to work for you I will test against it - and would be MUCH appreciated...!!!! There was another embedder or sorts on the net called "slingview" which actually does something like SkinBedder and I can grab it - but it has some confirmations in the way and would prefer using SkinBedder with RR....
    Much thanks if you could let us know the Class and Name that worked for you - I've tried everything I could find.....
    Thanks....!!!!
  10. #30
    Nov 2004
    L.A.
    I already sent you my whole skinbedder embed .ini file over PM. You still can't get it to work? Maybe you need to close the remote control. I've never tried it with the remote set to auto-show on startup.
  1. Problems embedding GPS application properly
    By Tim K in forum Road Runner
    Last Post: 07-27-2006, 11:26 PM
  2. Problem embedding in Roadrunner
    By tolisn in forum FreeDrive
    Last Post: 03-20-2006, 05:54 AM
  3. Embedding Alturion
    By stepir in forum Road Runner
    Last Post: 01-23-2006, 05:30 PM
  4. LQuickcam Embedding
    By crankshaft in forum Centrafuse
    Last Post: 08-20-2005, 10:37 PM
  5. Destinator still not embedding
    By RoyN in forum NeoCar Media Center
    Last Post: 11-09-2004, 08:56 PM
