Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: RadioSHARK v1 is now native to RR.
  1. #11
    Constant Bitrate Vineet Singh's Avatar
    Jul 2003
    Naperville IL
    Thats a great device! I just hooked it to the PS2 5v port via a tiny low voltage/amperage relay that gangs to a larger 10a relay, that just puts the antenna up if the carpc is on. I suppose you could do this with USB ports too.
    With that device, you could control items like:
    HVAC,
    remote start (I don't trust windows XP with that though ,
    automatic lights and/or voice command,
    bluetooth device unlock and/or ignition instead of using a physical key (pda or cellphone paired, on, and near the car) and more! Thanks!
    91 Stealth RT/TT
    CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
    Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
    Display: Lilliput 7" Touchscreen
  2. #12
    Constant Bitrate deus ex machina's Avatar
    Mar 2006
    If you want the antenna to go up whenever the car is on, you can just put it on the ignition line. I have mine going up when I go into the radioshark skin.
  3. #13
    Variable Bitrate Evolution VIII's Avatar
    Dec 2005
    Miami-Florida-USA
    The RadioSHARK is natively supported in official release of RoadRunner version 10-08-
    The RadioSHARK is natively supported in official release of RoadRunner version 10-08-06
  4. #14
    Jul 2003
    Naperville IL
    Schweet!
    91 Stealth RT/TT
  5. #15
    Oct 2005
    AWESOME!
    Worked like a charm... first try. WAY easier than I expected, especially since things are rarely easy on these car PC's... Thanks so much for the patch/support.
    Not sure why everyone is *****ing about the reception, seems to work just fine for me. I mean, it IS radio... And it sounds about the same as my stock head unit.
  6. #16
    Dec 2005
    Miami-Florida-USA
    For people that having problem running native radioSHARK
    Sorry guys for the long delay.
    Had a few minutes to test RadioShark native support problems and did not found any. I have downloaded the latest (RoadRunner Nov 12th 2006 Source Code) roadrunner source code from http://www.kompassist.co.uk/
    Here are my settings from rr.ini and these settings will work.
    Code:
    radiomode=6
    radiatorpath=C:\Program Files\Griffin Technology\radioSHARK\
    Please also check that your radioSHARK executable name is “radioSHARK.exe”
    JohnWPB
    Your problem is that you have full path to the radioSHARK.exe but you only need directory path.
    Code:
    RadioSharkPath=C:\Program Files\Griffin Technology\radioSHARK\radioSHARK.exe
    I also noticed that RRConfig.exe does not have a radioSHARK option in the dropdown box. I remember sending Guino code changes for it.
    Thanks.
  7. #17
    Dec 2006
    Radio Shark 1 is discontinued. Will the native features of radio shark work with radio shark 2?
  8. #18
    Dec 2005
    Miami-Florida-USA
    Quote Originally Posted by T_Blaze View Post
    Sorry, I don’t have a radioSHARK 2 and I’m not planning to buy one.
  9. #19
    Dec 2006
    I just ordered the radio shark 2, will let ya know if it works.
  10. #20
    Dec 2006
    maine
    any word? still in the planning stages and i'm thinking about getting one of these for those times when i actually need a radio! (drive-in movies, freeway conditions, emergency news, etc...)
  1. Radioshark to Car Antenna
    By theminor in forum Car Audio
    Last Post: 11-16-2010, 04:49 PM
  2. Help to get the Radioshark plugin working
    By grahamjuk in forum RR Plugins
    Last Post: 10-01-2006, 03:21 PM
  3. For those of you using the RadioShark
    By clinte in forum Car Audio
    Last Post: 10-19-2005, 02:27 PM
  4. R E V I E W: RadioShark
    By grepzen in forum General MP3Car Discussion
    Last Post: 03-09-2005, 07:38 PM
  5. radioShark am/fm usb adapter with timeshifting
    By kickerks80 in forum Car Audio
    Last Post: 10-04-2004, 05:08 PM
