First Post, Kewl
Very NICE!!!!! I have been using the Radio Shark plugin, and it works great! It will be very nice to have it built into RR so adding presets ect will be a snap!
Thanks for all your hard work!
RadioSHARK is now native to RR.![]()
- Available in the last RR official release (10-08-06) -
No special radio skins or plugins are required. RadioSHARK will work with the standard radio_player.skin included in most skins. However, you'll still have to patch your radioSHARK.exe.
CONFIGURATIONS (rr.ini)
Change radiomode value to 6 (radiomode=6)
Set path to RadioSHARK executable (RadioSharkPath=C:\Program Files\Griffin Technology\radioSHARK\ or whatever is the path on your computer)
Extra skin commands you can add to your radio_player.skin (Not required if you not using recording functionality of RadioShark)Code:radiomode=6 radiatorpath=C:\Program Files\Griffin Technology\radioSHARK\
BUTTONS
"RADIORECORD" - Start/Stop radio recording
"RADIOVOL+" - Adjust radioSHARK volume up
"RADIOVOL-" - Adjust radioSHARK volume down
"RADIOBAND" - Change AM/FM
"RADIOMUTE" - mute radioSHARK
INDICATORS
"RADIOMUTE" - Indicates if radioSHARK is Muted
"RADIORECORD" - Indicates if RadioSHARK is currently recording
LABELS
"RADIOVOLUME" -shows radioSHARK volume
"RADIOSTATUS" -Shows RadioSHARK status/recording status
Download RR beta version here. Please download and test. Don’t forget to backup/rename your existing rr.exe.
Download RadioSHARK patch here. Don't forget to patch you radioSHARK executable.
* Please download and test
First Post, Kewl
My Fiero Build Thread
Is it no one using RadioSHARK or everybody is just too lazy to post a feedback? People it is very simple: Without your feedback it will be no official RoadRunner release that includes native RadioSHARK support!
Please leave you feedback.
I've toyed with the idea of buying one but never heard anything about the reception.. If they are that good why is everyone holding out for the HCTWQ thingy?
RadioSHARK 3 times cheaper, and sound quality is better. HQCT hase better reception. I'm using HQCT myself.
I played with it for five minutes and couldn't get it to work at all. The radioshark application didn't start. The path to it was correct.
It's hard to test this because I either have to toy with it in my car on a 7" screen, or rip out my radioshark and bring it in the house. Also, the rr.exe you made doesn't have the corrected code for native IG, so even if I did get it to work, I couldn't use it yet.
I think it's funny how unpopular this whole project is too. After everything is straightened out, the radioshark will probably be the best option for a tuner.
1. That is correct. I do not have correct code for native IG. Is not released yet. Giuno will merge the IG code in to RR release.
2. Please check the RadioSHARK path in RR.ini, it should be the same as you used for the plugin in ExecTLB.ini and if you used radioSHARK plugin, please change you radio button code on the menu.skin from "RADIOSHARK" to "RADIO".
Very glad to see this is finally Native to RR. I will try it later.
Hardware: VIA-SP13000, M2-ATX, Voom case, HQCT, Linksys WiFi, Bluetooth, 512MB, 80GB, Dynamix 706.
Software: XP Pro (stripped), Drivers only, Road Runner, CentriFuse, EzSync
99% done... [never completely finished... a continuing hobby]
I use the RadioShark (and have it modded to connect to my retractable car antenna). It's not the best reception, but it works (and better than what is built into it)!
Right now I'm upgrading my carputer, and working out the new stuff I want to do with it. I will test it within a week (waiting on some parts).
Thanks!
91 Stealth RT/TT
CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
Display: Lilliput 7" Touchscreen
If you want to get your retractable car antenna working, pick up a Phidgets relay board.
