Page 13 of 13 FirstFirst ... 345678910111213
Results 121 to 126 of 126
Thread: How do I get the Car2PC adapter to work in RR?
  1. #121
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You may want to make a debug log to see if the button presses that "fail" are getting to RR at all. Regarding hibernation, this likely depends if you're putting them on a USB hub or something like that. I know for a fact that I had to plug my car2pc adapter directly on a USB port so it would work with hibernation -- but this was a hardware/driver limitation is seemed to me at the time.
    Ride Runner RR's Myspace
  2. #122
    Dec 2009
    Quote Originally Posted by guino View Post
    Thanks Guino for the response, I'll create a log file when I get home to the car later today.
  3. #123
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hi
    Guys can you pls help me...
    Well am able to use my NEW adapter with Skoda car steering wheel ( but only 2 switches )
    for -- previous and next song...
    Can some 1 pls help me with using the other switches...
    I mean how do i map those switches.. i have 3 more switches on the steering wheel and need to use 1 of them as a PAUSE function...
    All that i have done is copied the ExecTbl.ini from the post number 4...
    Thanks well in advance
    Vicky
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  4. #124
    Jun 2003
    Memphis - TN
    http://car2pc.com/software.html
    Go there and get the grom console..
    I believe you can press the buttons and see what buttons are what. Then you can assign commands through them via the Exectbl.ini
    Support on the adapter sucks! Ive emailed and asked questions many times and I never get a response. If I had another option with steering controls, I would have gone elsewhere.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  5. #125
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by vicky_obee View Post
    Hi
    Vicky
    Different cars offer different commands.. what you can do it enable debug log then press the buttons.. you should see the commands received by RR logged in the debug file, then you can define their actions in EXECTbl just like NEXT/PREV -- be sure to copy any " " (Spaces) in the commands received or it may not work.
  6. #126
    Sep 2005
    Pomona, CA
    Should these commands work? I'm just starting using my Car2PC adapter with RR (was using CF previously) on Win7.
    However, the main thing I really want is Car2PC display something on my HU display, like the track progress. I had this working with the plugin for CF, but it stopped working after resuming from hibernation sometimes...does this work at all in RR right now? I have the latest build of RR from last week.
    Quote Originally Posted by MatrixPC View Post
    - Install the driver (you already did).
    - Add usecar2pc=true to rr.ini if it isn't there.
    - Open RoadRunner's ExecTBL.in file and add the command in the list below if it isn't there. Also note that each skin may or may not has it own ExecTBL.ini file. The skin's ExecTBL.ini is NOT the file you want to look at.
    Code:
    /, Car2PC Interface Support
    "HUSTART","RESUME"
    "HUSTOP","PAUSE"
    "NT ","RRNEXT"
    "PT ","RRPREV"
    "PA ","PLAY"
    "FF 1","STARTFFWD"
    "FF 0","STOPFFWD"
    "FR 1","STARTFRWD"
    "FR 0","STOPFRWD"
    "DS 001","MENU"
    "DS 002","AUDIO"
    "DS 003","VIDEO"
    "DS 004","LOAD_PICVIEWER"
    "DS 005","PHONE"
    "DS 006","GPS"
    "MX 1","SHUFFLE"
    "MX 0","SHUFFLE"
    "RP 1","REPEAT"
    "RP 0","REPEAT"
    Those are the commands I use, change it to suite your need.
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
  1. RR and Radio - Don't work the scan indicator
    By slimmegane in forum Road Runner
    Last Post: 11-27-2005, 03:13 PM
  2. Repeat Doesn't Work for Winamp / RR
    By mousejunior in forum Road Runner
    Last Post: 06-16-2005, 01:51 PM
  3. tv in rr not work
    By manung in forum Road Runner
    Last Post: 05-13-2005, 12:10 PM
  4. One more time: Will this car adapter work?
    By S4Per in forum Power Supplies
    Last Post: 02-02-2004, 02:31 PM
  5. VGA to RCA adapter... will this work?
    By 700mx6 in forum Newbie
    Last Post: 01-10-2004, 08:46 PM
