Thanks, but I have no plugin for winamp. I know you mean the HU-plugin for winamp, but I didnīt install it, because I read that rr is working without the plugin.
Ti-ejtsch
Printable View
Ti-ejtsch
Try to install a different version of winamp than you already had in a different directory. Get a plugin and test it out. If it works, there is something wrong with RR. If it doesn't, well, either the adapter and/or driver or cables.
Do you mean a second installation of winamp with the HU-plugin? Or which plugin do you mean?
Ti-
Next song and prev song is working! Thanks a lot - but how could I change from audio-player to gps?
Now you know that the adapter is working with Winamp and HU-Plugin. The problem is with RoadRunner.
Un-install HU-Plugin and try with RoadRunner.
When you press D5 it RR will execute GPS command.
Try enable debugmode in RR to what if there is any error.
Hello,
thank you very much for helping me. Please tell me with the picture which button is D5, FR, FF, MX and so on. I mean the commands in the exectbl.
Man I wish I have a bimmer so I can help you better. May be you can loan it to me for a couple days :rofl:
Anyway, D1... D6 are direct dish selection. On Alpine HU, there are 6 of them corresponding to 6 dish on the changer. According to my ExecTBL.ini setting, if I press button label 6 (select Dish 6), the adapter/RR will execute GPS command.
Now I have no idea how you can do that with the button on the sterring wheel. I know most sterring wheel buttons only do D+ and D-.
The same with the Remote control I use to control the HU, I can't really use D+/D- to execute certain command associate with D1, D2 ... D6 without going from D1, D2.... D6
Hi,
I removed winamp car2PC plugin and nothing is working in rr. Not with the sterring wheel and not with the HU.
Ti-ejtsch
just out there but you said you added usecar2pc=true to rr.ini, but do you have car2pc.exe in RR's folder ? Also, I hope you're running one of the latest versions of RR.
If you would, please add debugmode=true to RR.INI, then make sure the winamp plugin is not installed, run RR, check the task manager if car2pc.exe is running, then press a few buttons on the steering wheel and post the debug log.
