Page 2 of 13 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 126
Thread: How do I get the Car2PC adapter to work in RR?
  1. #11
    May 2005
    Germany
    Thanks, but I have no plugin for winamp. I know you mean the HU-plugin for winamp, but I didnīt install it, because I read that rr is working without the plugin.
    Ti-ejtsch
  2. #12
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Try to install a different version of winamp than you already had in a different directory. Get a plugin and test it out. If it works, there is something wrong with RR. If it doesn't, well, either the adapter and/or driver or cables.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  3. #13
    May 2005
    Germany
    Do you mean a second installation of winamp with the HU-plugin? Or which plugin do you mean?
    Ti-
  4. #14
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Ti-ejtsch View Post
    Ti-
    2nd installation of winamp and HU-plugin.
    Or you can just install the HU-plugin with existing winamp to test if the 2 works with your HU and without RR. That way, you can narrow down that RR isn't the source of problem.
  5. #15
    May 2005
    Germany
    Next song and prev song is working! Thanks a lot - but how could I change from audio-player to gps?
  6. #16
    Sep 2003
    Beach City, Socal
    Now you know that the adapter is working with Winamp and HU-Plugin. The problem is with RoadRunner.
    Un-install HU-Plugin and try with RoadRunner.
    When you press D5 it RR will execute GPS command.
    Try enable debugmode in RR to what if there is any error.
  7. #17
    May 2005
    Germany
    Hello,
    thank you very much for helping me. Please tell me with the picture which button is D5, FR, FF, MX and so on. I mean the commands in the exectbl.
  8. #18
    Sep 2003
    Beach City, Socal
    Hello,
    Man I wish I have a bimmer so I can help you better. May be you can loan it to me for a couple days
    Anyway, D1... D6 are direct dish selection. On Alpine HU, there are 6 of them corresponding to 6 dish on the changer. According to my ExecTBL.ini setting, if I press button label 6 (select Dish 6), the adapter/RR will execute GPS command.
    Now I have no idea how you can do that with the button on the sterring wheel. I know most sterring wheel buttons only do D+ and D-.
    The same with the Remote control I use to control the HU, I can't really use D+/D- to execute certain command associate with D1, D2 ... D6 without going from D1, D2.... D6
  9. #19
    May 2005
    Germany
    Hi,
    I removed winamp car2PC plugin and nothing is working in rr. Not with the sterring wheel and not with the HU.
    Ti-ejtsch
  10. #20
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    just out there but you said you added usecar2pc=true to rr.ini, but do you have car2pc.exe in RR's folder ? Also, I hope you're running one of the latest versions of RR.
    If you would, please add debugmode=true to RR.INI, then make sure the winamp plugin is not installed, run RR, check the task manager if car2pc.exe is running, then press a few buttons on the steering wheel and post the debug log.
    Ride Runner RR's Myspace
  1. RR and Radio - Don't work the scan indicator
    By slimmegane in forum Road Runner
    Last Post: 11-27-2005, 03:13 PM
  2. Repeat Doesn't Work for Winamp / RR
    By mousejunior in forum Road Runner
    Last Post: 06-16-2005, 01:51 PM
  3. tv in rr not work
    By manung in forum Road Runner
    Last Post: 05-13-2005, 12:10 PM
  4. One more time: Will this car adapter work?
    By S4Per in forum Power Supplies
    Last Post: 02-02-2004, 02:31 PM
  5. VGA to RCA adapter... will this work?
    By 700mx6 in forum Newbie
    Last Post: 01-10-2004, 08:46 PM
