Page 4 of 13 FirstFirst 12345678910111213 LastLast
Results 31 to 40 of 126
Thread: How do I get the Car2PC adapter to work in RR?
  1. #31
    Oct 2005
    Raleigh, NC
    Steering wheel controls?
    Hi,
    Everything is working fine with RR and the car2PC adapter. I am looking to define the 2 steering wheel buttons, R/T and the one below it (looks like mute) in RR. Specifically, I'd like to use R/T to switch between music and gps screens (I already have the logic worked out) and the other button to mute winamp. Not sure if this help, but here are the entries extracted from a sample ibuscomm.ini file which gives the button info.
    Any ideas how to go about doing this?
    [ID:STW_PHONE_PRES]
    MsgTemplate="5004C83B8027"
    Label="S. Wheel phone Press"
    Parse=True
    ;winamp pause song
    KeyboardMap="c"
    [ID:STW_RT_PRES]
    MsgTemplate="5003C8019A"
    Label="S. Wheel - Press"
    Parse=True
    ;winamp play song
    KeyboardMap="x"
  2. #32
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Quote Originally Posted by MatrixPC View Post
    - Install the driver (you already did).
    - Add usecar2pc=true to rr.ini if it isn't there.
    - Open RoadRunner's ExecTBL.in file and add the command in the list below if it isn't there. Also note that each skin may or may not has it own ExecTBL.ini file. The skin's ExecTBL.ini is NOT the file you want to look at.
    Code:
    /, Car2PC Interface Support
    "HUSTART","RESUME"
    "HUSTOP","PAUSE"
    "NT ","RRNEXT"
    "PT ","RRPREV"
    "PA ","PLAY"
    "FF 1","STARTFFWD"
    "FF 0","STOPFFWD"
    "FR 1","STARTFRWD"
    "FR 0","STOPFRWD"
    "DS 001","MENU"
    "DS 002","AUDIO"
    "DS 003","VIDEO"
    "DS 004","LOAD_PICVIEWER"
    "DS 005","PHONE"
    "DS 006","GPS"
    "MX 1","SHUFFLE"
    "MX 0","SHUFFLE"
    "RP 1","REPEAT"
    "RP 0","REPEAT"
    Those are the commands I use, change it to suite your need.
    Ok I have done what Matrix PC said and it doesn't work for me. I am currently Beta testing for the car2pc for Mazda and it's just not working with RR. I installed a separate version of winamp to test the Hump plugin and that works. Jbors said to change PA to PL in the red line because PA=Pause and PL=Play but that still hasn't changed anything.
    Any other ideas?
  3. #33
    Jul 2005
    The car2pc program needs to be re compiled against the latest version of the
    FTD2XX Library.
  4. #34
    Sep 2006
    Do you think you can post the recompiled car2pc.exe? I'm not really sure what you have used to recompile the source code and I am not a programemr so my knowledge of this stuff is very limited.
  5. #35
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the source is on this thread, if you've successfully recompiled it with the new libraries, I'd like to get a copy of it myself to include with RR's release.
    Ride Runner RR's Myspace
  6. #36
    Sep 2006
    I've got the source. I downloaded a free copy of borland c compiler, but what or where is the "latetest" FTD2XX Library?
  7. #37
    Jun 2003
    Memphis - TN
    Man I hope we can get this working !
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  8. #38
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by durwood View Post
    Normally they have this posted somewhere on their forum or at car2pc.com I would think that if you simply provided the sources and asked nicely, someone could easily recompile it for you..
  9. #39
    Jun 2003
    Memphis - TN
    IF someone has it recompiled, I would like a copy as well.
  10. #40
    Sep 2006
    Thanks Guino, I wasn't directing this at you but I was trying to figure out the right people to ask. Jbors is aware we are having problems but it's hard to tell if he can or wants to help. Clarkie is the only one I am aware of that got it working and I was hoping he would help some of us others with more than just a few comments he made. I tried tracking him down in indashpc.org and here.
    Clarkie-
    Could you please post your working version of car2pc.exe? Then Guino could include it with RR to replace older versino of it.
  1. RR and Radio - Don't work the scan indicator
    By slimmegane in forum Road Runner
    Last Post: 11-27-2005, 04:13 PM
  2. Repeat Doesn't Work for Winamp / RR
    By mousejunior in forum Road Runner
    Last Post: 06-16-2005, 02:51 PM
  3. tv in rr not work
    By manung in forum Road Runner
    Last Post: 05-13-2005, 01:10 PM
  4. One more time: Will this car adapter work?
    By S4Per in forum Power Supplies
    Last Post: 02-02-2004, 03:31 PM
  5. VGA to RCA adapter... will this work?
    By 700mx6 in forum Newbie
    Last Post: 01-10-2004, 09:46 PM
