Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: relaunch of hqct-plugin
    Registered User
    Feb 2006
    Berlin, Germany
    Hi guino,
    after testing the newest software of datalex hqct-software Im impressed. the software is so much better than the rr-plugin. I found much more stations only with a paper clip as antenna as I found with real antenna and rrr-plugin. all stations were very clear, always like my headunit. this is the way it should be and you nevermore need a heasunit with carpc, rr and hqct. So can you re-launch the hqct plugin?
    thx
    Matthias
    Mar 2005
    Wiesbaden/Germany
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You should be able to just use the initialization settings from the new plugin in the HQTC application for RR and seve it, then it should have the same reception settings when you use it in RR.
    Ride Runner RR's Myspace
    Mar 2004
    Stockholm, Sweden
    Guino, any chance you can make the source for RRHQCT.EXE available ??? (i'm guessing this is Delphi code?)
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I can send you the sources, yes, but it's basically a modified version of the code the manufacturer made available, so not sure how much help it will be.. just PM me with your email address if you'd like it anyway.
    Mar 2004
    Stockholm, Sweden
    Seems XtroniC released a new version of RRHQCT. Anyone tried the new version yet ???
    USB Controlled radio - Available 27 Oct.
    http://www.xtronic.be/index.php?id=2&lang=2
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I tried it briefly and it seems to work fine. The source is also available -- it will be included in the next RR release as replacement for the old one.
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    nope not yet. I just seen you say something. I should be able to check it tomorrow. Im curious if it actually does work. Ill test it out tomorrow if i get a chance. Anyone used this yet? Im guessing i just dl the program and drop the files in the appropriate folders. Lets hope so.
    lol guino beat me too it.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
    Variable Bitrate Evolution VIII's Avatar
    Dec 2005
    Miami-Florida-USA
    HQCT playing on two front speakers only.
    I'm aware that HQCT module uses “CD audio” connector on motherboard for audio input. Which is a stereo (LEFT, GRND, GRND, RIGHT). However, MP3s and Videos playing on all four speakers.
    What do I have to do to make HQCT play on all four speakers on my VIA EPIA SP13000 board?
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    I'm not claiming to know anything about the HQCT as i don't have 1 but my Wintv tv tuner is dual mono but still comes out of all 5.1 speakers.
    This in my system is done by either winamp (most likely) or the soundcard (audigy 4 pci),i'm not exactly sure which.
    Look in your soundcard options and winamp for Stereo Upmixing.
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 12:32 PM
  2. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 10:07 PM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 05:10 PM
