do you have the gps com port in RR set to the same com port as IG ?
Okey i have iguidance working in my carputer but i have a weird thing happening......if i run ig outside of rr it detects the gps antenna with no problem....and works well...however when i launch ig from inside rr (embedded) it does not detect the gps antenna !@#$^&*() any ideas ???![]()
http://www.sounddomain.com/ride/856246
Please visit my new site http://www.Gigabitcustoms.com
My worklog http://www.mp3car.com/vbulletin/show-off-your-project/52720-project-rr.html
beer replenishment fund
mp3car live search
My worklog http://www.mp3car.com/vbulletin/showthread.php?t=52720
You need to change it to something else. iGuidance will manage the com port on it's own.
thats the problem, that they are both set to the same com port.
AFAIK IG will not manage a com port on its own, you have to set it or scan for it, but once you do it once, it will remember.
What you need to do is either disable the com port in RRConfig, set it to zero
OR, do a search for xport which is a com port splitter. Xport will allow you to have multiple applications connect to the same gps device, by default gps devices only allow one connection to its port at a time.
When you split the com port you can then create virtual comports that have different numbers but all contain the same data. So you can RR, IG and other gps apps all running at the same time.
mp3car live search
To sum it all up... You can't have RR and IGuidance set to the same port. They will both try to access it and RR will win! So... just change the port in RRConfig and you'll be fine.
K301 7" Motorized Screen
Mini SLIMPRO SP625 Cappucino PC
RoadRunner / IGuidance 3.0
Pioneer 7700MP HU
MTX 1500D 1500 Watt Sub Amp
2 x 12" MTX 8000 subs
1998 Olds Aurora 4.0 V8
Yeah ditto.
Just installed my GPS receiver, IG, ran into the same problem. A Quick "Search" and bingo! All's good.
Hey, in RRConfig, what is the "Window Name" for IGuidance? (Not the new 3.0, the older one)
Thanks for the help.
