Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Flash expert needed
  1. #11
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    :d
    2001 S10 ZR2
    Chucks Skin - to old
  2. #12
    Ft Lauderdale, FL
    No problem,
    If anything check in the Flash help panel, they have code examples for almost every command.
  3. #13
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Kembond
    If you get board and want something to do here is my timer
    I all most give up
    Attached Files Attached Files
    2001 S10 ZR2
  4. #14
    Ft Lauderdale, FL
    Here you go.
    I started from scratch, it was easier for me that way.
    I Let it run for 13 minutes and it worked fine, but you might want to let it run for awhile, at least get an hour.... just to make sure.
  5. #15
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Kembond you miss understood me
    The other timer worked fine
    I was just trying to add the color change thing as the one above
    2001 S10 ZR2
  6. #16
    Ft Lauderdale, FL
    Doh!
    My bad, you did not really explain what the problem was in that post, so I just assumed that was the issue. When I played it, and I clicked to stop the timer it went to zero, so I thought you wanted it to pause.
    Oh well.
  7. #17
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Kembond I really appreciate your help
    I just have a hard time with the layer frame things
    Thx again
    2001 S10 ZR2
  8. #18
    Ft Lauderdale, FL
    No problem, anytime.
  9. #19
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    How can I have this quit or close itself after it plays the sound or after so many seconds?
    edit
    I will have this as a chime.exe and would like it to close when it is done playing the bell.
    It will end up being an hourly chime with guinos TIMEEXEC.DLL plugin
    2001 S10 ZR2
  10. #20
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    I know how to close it with a button but not with time or at end of play
    on (release) {
    fscommand("quit");
    2001 S10 ZR2
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 07:23 PM
  2. help needed with flash Clock
    By Nomader in forum Road Runner
    Last Post: 06-26-2006, 04:07 PM
  3. Flash solution needed
    By netrider in forum Software FAQs, Solutions, Tutorials
    Last Post: 01-23-2006, 06:08 AM
  4. Open Call, Flash help needed for tracker !!!!
    By frodobaggins in forum Software & Software Development
    Last Post: 05-08-2005, 06:25 PM
  5. Help needed from VB expert !
    By CdRsKuLL in forum Software & Software Development
    Last Post: 12-27-2004, 03:28 PM
