Results 21 to 30 of 32
Thread: Flash expert needed
  1. #21
    Ft Lauderdale, FL
    Here you go Chuck.
    Attached Files Attached Files
  2. #22
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Kembond Thank you
    2001 S10 ZR2
    Chucks Skin - to old
  3. #23
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Ok, I am trying to load an image on start of the flash instead of the preloaded one.
    I can get an image to load but it loads over top of the date and time so you canít see it.
    Any help would be appreciated
    2001 S10 ZR2
  4. #24
    Ft Lauderdale, FL
    Anything loaded at runtime either externally or from the library will always be on top of whats on the stage. You would have to load the date and time mc from the library then you could control which one was on top.
    The work around which I did is to put a blank mc on the stage below the date and time and above the current bkg and then load the external image into that clip.
    Your good to go.
    PS: I changed the text to white just so I could see it.
  5. #25
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Kembond Thank you again
    You make it look easy
    2001 S10 ZR2
  6. #26
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Kembond do you think you could do the same to this?
    2001 S10 ZR2
  7. #27
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Never mind I figured it out
    2001 S10 ZR2
  8. #28
    Ft Lauderdale, FL
    Glad you got it working.
    I made this component, might be able to use it in the future. It will allow you to attach an image dynamically, and you can position it on the stage like normal.
  9. #29
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Thatís neat
    Kembond is there a way I could load these colors from a txt file on load?
    Code:
    // COLOR CHANGE
    var $color1 = 0xFFFF00;
    var $color2 = 0x00FFFF;           //<<<<<<<<<<   load colors on start from color.txt file
    var $color3 = 0xE6E6E6;
    var $color4 = 0x000000;
    var myListener:Object = new Object();
    myListener.onKeyDown = function() {
    	var my_fmt:TextFormat = new TextFormat();
    	if (Key.isDown(Key.CONTROL) && Key.getCode() == 89) {
    		my_fmt.color = $color1;
    	} else if (Key.isDown(Key.CONTROL) && Key.getCode() == 66) {
    		my_fmt.color = $color2;
    	} else if (Key.isDown(Key.CONTROL) && Key.getCode() == 80) {
    		my_fmt.color = $color3;
        } else if (Key.isDown(Key.CONTROL) && Key.getCode() == 75) {
    		my_fmt.color = $color4;
    	currentfmt = my_fmt;
    Key.addListener(myListener);
    function setTextColors() {
    	display_mc.date_txt.setTextFormat(currentfmt);
    	display_mc.time_mc.time_txt.setTextFormat(currentfmt);
    2001 S10 ZR2
  10. #30
    Ft Lauderdale, FL
    Here you go Chuck.
    Code:
    // COLOR CHANGE
    var colorArray = new Array();
    var colorLoadVar = new LoadVars();
    colorLoadVar.onLoad = function(success){
    	if(success){
    		trace("Loaded");
    		addColorsToArray(colorLoadVar);
    	}else{
    		trace("Not Loaded");
    colorLoadVar.load("colors.txt");
    function addColorsToArray($data){
    	var $num = $data.colorNum;
    	for(var i=0;i<$num;i++){
    		colorArray.push($data["color"+i]);
    	delete colorLoadVar;
    		my_fmt.color = colorArray[0];
    		my_fmt.color = colorArray[1];
    		my_fmt.color = colorArray[2];
    		my_fmt.color = colorArray[3];
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  2. help needed with flash Clock
    By Nomader in forum Road Runner
    Last Post: 06-26-2006, 05:07 PM
  3. Flash solution needed
    By netrider in forum Software FAQs, Solutions, Tutorials
    Last Post: 01-23-2006, 07:08 AM
  4. Open Call, Flash help needed for tracker !!!!
    By frodobaggins in forum Software & Software Development
    Last Post: 05-08-2005, 07:25 PM
  5. Help needed from VB expert !
    By CdRsKuLL in forum Software & Software Development
    Last Post: 12-27-2004, 04:28 PM
