Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Flash expert needed
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Flash expert needed
    I am trying to change text color from keyboard commands to a flash.exe
    Control+y = Yellow
    Control+b = Blue
    Control+w = white
    So I can activate and sendkey from RR to change colors
    It would probably take me a week to figure this out but some of the people on here could probably do it in 5 minutes.
    I will post the .fla file I am working on if someone wants to give it a shot
    Thx chuck
    ps post 1000
    Attached Files Attached Files
    2001 S10 ZR2
    Chucks Skin - to old
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    are you using this flash file as a SWF defined in the .skin file or as an EXE file embedded with the LOAD command ? I'm pretty sure SWF files will not receive keyboard input (so that would not work).
    Ride Runner RR's Myspace
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    This is an .exe embedded just to set it in place.
    now i just change exe to change color - funky to watch
    PHP Code:
    "CHUCKSTOP","LOAD;CHUCKSTOP.skin||BYVAR;COLORPICK;RUNTOPYELLOW<<RUNTOPBLUE<<RUNTOPWHITE||EXIT||SHOWWINDOW;ChucksTop;True"
    "CLOSECHUCKSTOP"
    ,"ACTIVATE;ChucksTop||SENDKEY;%{f4}"
    "RUNTOPYELLOW"
    ,"RUN;$CHUCKSPATH$ChucksTopYEL.exe;ChucksTop"
    "RUNTOPBLUE"
    ,"RUN;$CHUCKSPATH$ChucksTop.exe;ChucksTop"
    "RUNTOPWHITE"
    ,"RUN;$CHUCKSPATH$ChucksTopWHT.exe;ChucksTop"
    2001 S10 ZR2
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    actually guino i've had success sending keystrokes to flash with the new solid tag. I'll take a look at this for ya chuck. Least i'll try to.. i think my flash trial expired (swishmax FTW!)
    Live mp3Car Facebook Chat
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I don't understand one thing though... I mean, you're MAKING this flash file, so why don't you just have the color in the flash file selected by a global variable you set in RR ? That's what "setflashvar" is for... "SETFLASHVAR;COLOR;2"
    then use:
    if (_root.COLOR == "2") {
    <COMMANDS TO CHANGE THE COLOR/FRAME etc>
    That's coming from someone who knows nothing about flash.. and again that's only useful if there's no special reason why you're using keystrokes to get the job done.
    Ft Lauderdale, FL
    Here you go Chuck, hope this is what you were looking for.
    But if you test it within the flash ide, make sure you select "Disable Keyboard Shortcuts" from the "Control" menu in the swf preview, or else is won't work.
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by guino View Post
    then use:
    Will this work with an flash.exe?
    2001 S10 ZR2
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by kembond View Post
    Kembond thanks a bunch
    Works good but every time the time or date changes the color goes back to the startup color
    Almost there
    2001 S10 ZR2
    Ft Lauderdale, FL
    Your all set.
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Kembond thanks a million
    Works like a champ
    Now I have a timer to do but I think I can do it from your example
    Thanks again
    2001 S10 ZR2
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  2. help needed with flash Clock
    By Nomader in forum Road Runner
    Last Post: 06-26-2006, 05:07 PM
  3. Flash solution needed
    By netrider in forum Software FAQs, Solutions, Tutorials
    Last Post: 01-23-2006, 07:08 AM
  4. Open Call, Flash help needed for tracker !!!!
    By frodobaggins in forum Software & Software Development
    Last Post: 05-08-2005, 07:25 PM
  5. Help needed from VB expert !
    By CdRsKuLL in forum Software & Software Development
    Last Post: 12-27-2004, 04:28 PM
