Results 1 to 6 of 6
Thread: Need help big time!
    Oct 2006
    Need help big time!
    i bought the lilliput 7inch touch screen, i cant get it to support 800x600 which seems to be the default res for roadrunner and its default skin. I can get it to run 1024x768 and 640x480. Although roadrunner doesnt line up properly! I tried setting the size to 640x480 in the road runner config file but it doesnt change anything.. I need help! any idea's? Im runnin out of time, car pc is schedualed to go in on sunday =(
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Hello Mate,
    There is a file called General.ini which is in your skin directory, for the skin that your using. In it are the commands that will resize the skin you are using to the screen size you are using. edit this file, save it and restart Road Runner, and this should sort your problem.
    cheers
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Its sounds silly but check the supported resolutions for you graphics card and make sure you have the latest drivers for it and your lilli installed.
    Set the RR config option to Default.
    You can also change the skin size in the general.ini which can be found in the skin file,This is 1 from BMV2
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=800
    ShowHeight=600
    XPosition=0
    YPosition=0
    ApplyToVideo=False
    ApplyToVisu=False
    AutoSwitch=False
    DayTime=8:00:00 AM
    NightTime=6:00:00 PM
    GammaDayRed=0
    GammaDayGreen=0
    GammaDayBlue=0
    GammaNightRed=-40
    GammaNightGreen=-40
    GammaNightBlue=-40
    Just change ShowWidth to 640 and ShowHeight to 480.
    I can't say for sure but there maybe some image loss if you do it that way.
    Nov 2005
    Midlands
    Damn,you beat me to it.
    Dec 2003
    West Midlands
    Aaah but yours was so eloquent !
    cheers m8
    KPJUK
    Oct 2006
    woohoo thanks!!! fixxing the general ini file worked! you guys are AMAZING
  1. Invalid Argument
    By tn6478 in forum StreetDeck
    Last Post: 12-30-2007, 09:02 PM
  2. Features I would like to see in Streetdeck
    By Gayden in forum StreetDeck
    Last Post: 08-04-2006, 01:49 PM
  3. Capacitor time formulas (for noobs)
    By KyleYankan in forum Newbie
    Last Post: 03-30-2005, 04:32 PM
  4. Optimize Load time of CF?
    By HostileJava in forum Centrafuse
    Last Post: 03-16-2005, 08:40 AM
