Originally Posted by
MGD
Yes, you can do this with the IDL Command.
There is a entry in the Exectbl.ini file for a timer event.
Then use the IDL,5 for 5 sec delay.
There are two commands you can use.
/, (IDL) Idle Timer
/, Seconds
IDL,XXX
The above defines the number of seconds in "IDLE" state (no mouse/keyboard actions) to
execute the "IDLE" event that can be defined in ExecTBL.INI so a command is executed at such time.
/, (TMR) Timer event
/, Seconds
TMR,XXX
The above defines the number of seconds after loading the screen RR will wait to
execute the "TIMER" event that can be defined in ExecTBL.INI so a command is executed at such time.
This event is re-occurring, so every few XXX seconds it will re-execute the TIMER event. You can use
a simple variable switch to prevent it from executing your command more than once (if desired).
Put this in the name.skin file you want to have timed.
IDL,5
and put this in exectbl.ini
"IDLE","EXIT"
Now, when there is no movement of the mouse for 5 sec. the screen will be closed.
