I have seven USB devices and they do not change addresses, unless I have swapped cables/devices around. The first thing I can think of is one of your USB devices is not installed correctly, that would cause this problem. Try setting one USB device at a time, shutdown and reboot a few times, see if it is pulling the same address/IRQ in device manager everytime (that is if you are running a windows platform). Do this for the remaining devices, then if all is well, run RR, etc.
LinkBack URL
About LinkBacks
