Results 1 to 7 of 7
Thread: MapPoint 2006 Voice Prompts
    Jul 2005
    I'm using RoadRunner's current beta. When I run MapPoint by itself, it provides voice prompts. When I run it inside RR (activeX control), I get text but no voice. Anyone experiencing similar behavior, and does anyone have the voice prompts working?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    RR has built in functions for directions/voice guidance -- independent on Mappoint (since older versions did not really support driving guidance). As long as you have voice enabled in RRConfig and you use RR's screens to set the route, it should work.
    Ride Runner RR's Myspace
    Variable Bitrate Evolution VIII's Avatar
    Dec 2005
    Miami-Florida-USA
    I'm having the same problem as CSharper. RR doesn’t speak directions. The direction indicator image doesn’t work either. I noticed that in the route list stays highlighted on the first item.
    I’m using latest RR Beta, MapPoint 2006, and Voice is enabled in RRConfig.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    it will only speak if you're following the directions as noted, and you must create it while not on a highway/freeway... I'll test it again to be sure, but it should work.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I did test this and it worked fine for me.
    Dec 2005
    Miami-Florida-USA
    Quote Originally Posted by guino View Post
    Any suggestions where the problem could be?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The direction indicator only works with FD and MM (it was never made to work with mappoint).
    The route list should highlight the following direction, if that's not happening, there's something wrong happening. As long as you're following the directions as listed, and you have created the route while not on a highway/freeway, it should be working. Also, double check you have mappoint.ini in place -- if anything, replace it with the original one.
  1. Centrafuse New release & mappoint 2006
    By josgab in forum Centrafuse
    Last Post: 09-06-2006, 11:00 AM
  2. MapPoint 2006, MapPoint GPS, Autoroute...
    By tomcat in forum StreetDeck
    Last Post: 08-14-2006, 12:21 PM
  3. Replies: 5
    Last Post: 06-25-2006, 11:27 AM
  4. Mappoint 2006 with RoadRunner Help???
    By surf2130 in forum Road Runner
    Last Post: 05-25-2006, 06:32 PM
  5. Replies: 6
    Last Post: 09-29-2005, 06:50 PM
