Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
Thread: RR & Iguidance problem
  1. #21
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    have you tried the xport splitter?
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  2. #22
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    ive seen #1 happen but rarely with the taskbar, i have another application that is supposed to be set on top of any other window but RR always covers it up no matter what. Not really sure what can be done by us in respect to that.
    #2
    Does this happen when you run IG standalone? I have the same gps device as you and i also have this same problem, others also have this problem in the GPS section. This has nothing to do with RR on my end or others that have it also. For some reason IG3 dosent lock on to sats when its supposed to, even though its recieveing gps data and you can see the alt,lat, and speed readings, just no tracking on the maps.
    For the earthmate gps device, it has an icon in the tray that controls the port splitting, whenever i click on it, IG will instantly lock on sats so i think think whatever the problem is, it is specific to IG3, IG2 never did it, no other gps apps have a problem on my system. So im not sure what can be done about this issue either. Some people get it, some dont. Im just waiting and hoping for an IG3 update.
    For those with IG embed issues, im almost certain this is a setting/config issue somewhere in your setup. Ive never had problems embedding IG or the map moving no matter what RR release, either on my dev machine,test machine or carputer.
    Im willing to work with someone to try to fix it though, if you zip up your entire RR dir and PM me, ill give you somewhere you can upload it to.
    beer replenishment fund
    mp3car live search
  3. #23
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Here is the method I am using now to show the map
    Code:
    “GPS”,”LOAD;EXTERNAL_GPS_ig.skin;;C:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance||SHOWMAP”
    "EXIT","TEMPEXIT||RETURNMAP"
    "TEMPEXIT","EXIT"
    "RETURNMAP","SHOWMAP",EXTERNAL_GPS_IG.skin
    "RETURNMAP","SHOWMAP",EXTERNAL_GPS_ig_FS.skin
    "SHOWMAP","SHOWWINDOW;iGuidance;False||SHOWWINDOW;iGuidance;true"
    2001 S10 ZR2
    Chucks Skin - to old
  4. #24
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    GPS and iGuidance
    Quote Originally Posted by durwood View Post
    I have two problems at the moment and I have searched and read and still unsure if I have something set wrong.
    1) Anytime I switch to the GPS screen, the taskbar pops up indicating that roadrunner does not have focus?? I then have to click back on the roadrunner GPS window to bring roadrunner back into focus..
    I also have had #1 happen quite a bit since the first ignative release and still occuring with the iGAuto build. . I even tried autohiding the task bar, but it will still come up at times.
    2) To get my GPS receiver to talk to IG I must go into the IG GPS settings and then return back to the map screen. How do I get my GPS reciver to always be active or talking to IG whenever it needs it?
    This does seem to be an iG3 issue. I have found two things that have helped with this, if you are using a delorme receiver, with the delorme serial splitter, try setting the port for iGuidance to RAW. This solved the problem with my receiver completely in my case.
    If that does not work, then give XPort a try, as that fixed the issue as well.
    The only reason I know these are both "Fixes" is I purchased a MS branded Pharos GPS device and put it in the car, and replaced the Delorme serial splitter with Xport, and now I have a lock faster than I can get to the iG screen when RR does a cold boot. It immediately starts tracking.
    I moved the Delorme to my dev machine and had the same fracking problem with iG not getting a location, even though the Delorme utility reported 8 satellites locked. I just started trying things, and set the port for RR to RAW in the Delorme serial splitter, and INSTANTLY iG got a lock, and does so every time now if the receiver itself gets a lock.
    Not real sure what the technical reason is, but I would assume that iGuidance does not like the info tampered with at ALL, and prefers the straight raw info.
    My Fiero Build Thread
  5. #25
    Aug 2003
    Chicago
    Quote Originally Posted by JohnWPB View Post
    im going to go out and try this right now, ive done everything under the sun to try to fix this. Glad you got a solution. Something always told me it may have something to do with the port splitter built into the delorme drivers, but i didnt have a copy of there older drivers without the port splitting to test and they dont offer them to download. Hopefully setting it to RAW fixes it for me, ive never had good luck with xport, does funky things to my box. But, ive been wanting to get a new gps mouse for a while so if this dont work thats the next stop
    mp3car live search
  6. #26
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Quote Originally Posted by Chuck View Post
    Code:
    "TEMPEXIT","EXIT"
    Does that go in RR.ini? I think the taskbar/embed issue is that IG tries to full screen and that is when RR loses focus. I can zip my entire rr settings and send it to you later if you are wiiling to help. Just let me know where to send it.
    #2 happens in or out of RR so I think you are right it sounds like an IG problem. I tried setting the Delorme Serial splitter program to RAW and I monitored it ans it was getting all sorts of satelites but in IG the GPS status didn't see anything. Set back to NEMA and open IG, then click gps status and that is when IG works. So RAW in the delorme is a no go.
    I'll have to try the xport program later.
  7. #27
    Sep 2006
    #2 problem fixed Thanks guys. Tired the delorme serial emulator with xport3 ver 11/02/06 program works good now Everytime even form hibernation.
    I am still working on problem #1
  8. #28
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Here is a good example of the map not showing but it is embedded
    Running another window over the map
    2001 S10 ZR2
  9. #29
    Nov 2006
    i too am having this issue with it connecting but not showing the sats (0/0) but the lat and long tick away but the gps does not show the car moving.
    xport has been a failed on my system. i will try xport3 ver 11/02/06, just need to find it.
    1997 corvette c5
    toshiba laptop 2.4
    1 gig ram
    dvd-rw
    8" lilliput ws ts
    Delorme usb
    road runner / blue devil
  10. #30
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Hey guys, if you have problem with RR embedded and/or not showing map, try disable transition effect to see what happen.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Replies: 16
    Last Post: 12-17-2009, 04:26 PM
  2. Replies: 570
    Last Post: 11-05-2009, 02:49 PM
  3. Replies: 0
    Last Post: 09-23-2006, 08:38 PM
  4. iGuidance GPS Issue in RR
    By moeman_49 in forum GPS
    Last Post: 06-04-2006, 03:17 PM
  5. Iguidance reroute problem?
    By samc in forum GPS
    Last Post: 10-02-2004, 10:49 PM
