more info is needed.
what skin are you using.
what version of RR are you running
Does IG embed into RR?
what do you have in RRConfig for gps window name?
Do you have ignative=True or False in RR.ini
I did a search but didn't find an answer. I am using the latest version of RR and Iguidance 3. Everything works great except when I switch between screens on Iguidance to RR. For example I start RR, then hit the GPS button and I guidance loads. Then if I choose music and then go back to Iguidance, the map doesn't show unless I click on the map and drag it then it will show. Is there a reason for this? Anyway to fix this problem?
beer replenishment fund
mp3car live search
My Fiero Build Thread
I have the same problem on two machines with v2.1.2
Now if in the truck and going down the road its ok but if I stop and switch screen no map.
The only way I could get it to work was at the end of the load command.
||ACTIVATE;iGuidance||SENDKEY;{RIGHT}{RIGHT}”
Or load IG with the window name !Intellinav so it will load like any other app but you will have the menu bar at the top.
I think RR needs to send a redraw to IG some how - maybe
How do I send a command back so the images comes back automatically instead of having to press and hold the screen somewhere? I'm using the latest RR and the skin that came with it. IG is embbed with no problem other then not showing up when I switch to something else (music, video, etc.) and back. Its not a real big deal but it does get annoying that I have to click and drag for the map to show up again.
I have the same problem.
Hi, so does anyone have a fix for this problem? Or is it just specificly some systems? or what causes this?
Same problem here. with the latest release only. Never had the issue in the past. Sucks.
If you can't understand what's been posted, just open RR.INI set (or add) ignative=false and call it the day.
Ride Runner RR's Myspace
