There were requests of the GPS updating the heading too frequently, so there's a thresshold now to only update the heading with speeds above 3Mi/h. Apparently this is an issue with some GPS models (reporting multiple headings while stopped).
Guino,
I'm running the beta version but I tried the 10/08/06 with the same results.
Problem the GPSHDG is not updating.
The GPSALT and GPSSAT are working. Don't know about the GPSSPD as I pulled my CarPC out of the truck last night when I saw the problem and have been bench testing it since.
My gps software is seeing the heading change, the port monitor of my virtual port splitter is seeing the change. I ran a program called compass and it's seeing the change. I tried three different skins and one of them I've been using for months. I don't drive very often, so I can't say when this happened for sure. Changed the ports in RR.ini to make sure and it didn't help.
In google earth/RR it seeing the GPS location on the bench.
Just need some help or tell where to look.
Thanks..
Ride Runner RR's Myspace
Dang!!
I searched last night for this and didn't see anything. I guess I forgot the Readme.txt update from the past.
Thanks for the quick response and sorry to bother you..
Well, I cleaned under the center console anyway.
