Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 61
Thread: New FM USB module, maybe good for our carputers?
  1. #31
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    I saw the HID device yesterday too after looking around. Here's what I got with USB Mon...
    Vendor: 0x06e1 (ads technologies, inc.)
    product id: 0xa155
    manufacturer: 0x0409: ads tech
    I attached a few seconds of the radio connected and then playing with the instantradio software, to the log file of the data package capture with usb mon. captured just the HID portion. hope this helps... cuz I have no clue about any of this. cheers...
    Here's the full subtree copy/paste for the device
    Code:
    USB Root Hub
        Port1: USB Composite Device
            Hub Power: Self Power
            Number of Ports: 2
            Power switching: None
            Compound device: No
            Over-current Protection: Individual
            Device Descriptor
                USB Version: 1.1
                Device Class: (0) Reserved (defined in Interface Descriptor)
                Device Subclass: 0
                Device Protocol: 0
                Max Packet Size: 0x40 (64) bytes
                Vendor: 0x06e1 (ADS Technologies, Inc.)
                Product ID: 0xa155
                Product Version: 0x0100
                Manufacturer: 1
                    0x0409: ADS TECH
                Product: 2
                    0x0409: ADS InstantFM Music
                SerialNumber: 0
                Number of Configurations: 1
            Connection Status: Device Connected
            Current Configuration: 1
            Device Bus Speed: Full
            Device Address: 0x02
            Number of Open Pipes: 2
            Configuration Descriptor (1)
                Total Length: 145 bytes
                Number of Interfaces: 3
                Configuration Value: 1
                Configuration: 0
                Attributes: 0x80
                    Bus Powered
                Max Power: 0x32 (100 Ma)
            Interface Descriptor (0)
                Interface Number: 0
                Alternate Setting: 0x00
                Number of Endpoints: 0x00
                Interface Class: (1) Audio (Audio)
                Interface Subclass: 1 (Audio Control)
                Interface Protocol: 0
                Interface: 0
            Interface Descriptor (1)
                Interface Number: 1
                Interface Subclass: 2 (Audio Streaming)
                Interface: 0
                Interface Number: 1
                Alternate Setting: 0x01
                Number of Endpoints: 0x01
                Interface: 0
            Endpoint Descriptor (Addr: 0x83)
                Endpoint Address: 0x83, Input
                Transfer Type: Isochronous
                Max Packet Size: 0x0200 (512) bytes
                Interval: 0x0001
                Sync Address: 0x00
            Interface Descriptor (2)
                Interface Number: 2
                Number of Endpoints: 0x02
                Interface Class: (3) Human Interface (HID)
                Interface Subclass: 0
                Interface: 0
            HID Descriptor
                HID Version: 0x0111
                Country Code: 0x00 (0)
                Number of Descriptors: 1
                    Type: 0x22, Length: 0x00cb bytes
            Endpoint Descriptor (Addr: 0x81)
                Endpoint Address: 0x81, Input
                Transfer Type: Interrupt
                Max Packet Size: 0x0040 (64) bytes
                Interval: 0x0a
            Endpoint Descriptor (Addr: 0x02)
                Endpoint Address: 0x02, Output
                Interval: 0x01
    Attached Files Attached Files
  2. #32
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    this may be the choice of radio! thanks W3bMa5t3r!
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
  3. #33
    Mar 2006
    alright, i tried my instantFM in the car on the way to work this morning. it worked pretty well with the included retractable antenna. under a tunnel it cut out and my head unit fm worked fine. i think if i can adapt the connection to use my car's antenna i can get some better performance. i'm going to try to work on that this weekend. anyone have any luck getting the SDK yet so we can get this working in a front end?
  4. #34
    Mar 2006
    i just received the sdk from ads. i'm not a very experienced coder but i'm going to look through it all tonight. what would we need to do to make this work with RR or CF?
  5. #35
    Mar 2005
    Wiesbaden/Germany
    sorry I lost this thread....
    I remember as my amazon order (I just ordered because I was just curiously) with the ADSTech arrived...
    I opened it and it is a 99% copy of the Silabs PCB !
    So If you like to waste your time go ahead and code a driver.
    Or just contact the Silabs driver guys...
    and:
    Why not just coding a driver for every frontend ?
  6. #36
    Mar 2006
    Quote Originally Posted by FMode View Post
    and:
    obviously nobody likes to waste their time. who are the "silabs driver guys" that i should contact? and by getting their driver, how should i use it in a front end? could you provide more information?
  7. #37
    Mar 2005
    Wiesbaden/Germany
    Quote Originally Posted by jbolter View Post
    hmm.... I don't think so if I see what is done sometimes in the carpc community !
    search for "Silabs" in this forum...
    You get the "point" of my software (FMRadioHAL) !
    This is crapped in nearly all Frontends expect Centrafuse and here the radio driver interface is somewhat under development and nearly 20% (IMHO) finished.
    (and this is certainly also caused by the users of the Frontends asking can "car-xyz support my ding-ding-radio" instead of looking at MS Office realizing that it uses drivers to access printers and then "kicking" for the developer (expect RR) - "use a driver to access the radio!"
    and see where we are discussing... )
  8. #38
    Mar 2006
    so is the goal for me to get the "point" of your software? because i get the point, but i'm still not sure how that helps me get my ADS radio working in a front end...
  9. #39
    Dec 2006
    The radio software that came with ADS uses a customizable skin. You can edit this skin using Active Skin 4.x. I think this software has been discontinued, so it was hard to get it, but I eventually got the shareware version.
    I was also able to embed the radio app in RR using Skinbedder .
    Now, all I have to do is to create a skin that goes along with my RR skin. This way, you get the RDS information(song title/artist/station id, etc) as well that Radiator does not support.
    I didn't notice anything when I attached it to my laptop, but when I connected it to a 2.1 setup , I noticed a lot of popping noise from the radio not constantly, but from time to time.
  10. #40
    Mar 2005
    Wiesbaden/Germany
    Where is my posting ???
    okay again:
    Ask the Silabs developers if they can move the vendor and product id from "hardcoded constant" to a file/registry (which is loaded at startup).
    Get their work and change Vendor to 0x06e1 and Product ID to 0xa155 and start...
    I can also have a quick look at the sources (VB6 and .NET only) if I got them...
    I have a HQCT, Silabs and a ADSTech...
    (sorry for no more help but HQCT is first)
  1. Holux GM-213 USB GPS Receiver, Good?
    By girbot in forum GPS
    Last Post: 04-24-2006, 12:35 AM
  2. Replies: 8
    Last Post: 02-13-2006, 02:27 PM
  3. FM Radio through USB
    By JohnChimpo in forum General Hardware Discussion
    Last Post: 11-09-2004, 02:54 PM
  4. FM radio card.... (USB?)
    By chuckctv in forum FrodoPlayer
    Last Post: 10-25-2004, 09:15 AM
  5. USB FM solution good or crap?
    By Jake in forum General Hardware Discussion
    Last Post: 10-03-2002, 02:56 PM
