Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 61
Thread: New FM USB module, maybe good for our carputers?
  1. #41
    Dec 2006
    I downloaded the source code for USBRadio.dll radiator plugin for silabs reference fm (should be similar to ads, similar chipset), changed vendor/product id using what I got from my device (the same value as you specified), and successfully compiled it. No errors, but radio module doesn't work.
    That module is known to work among silabs reference modules, but I guess there are more differences than some ID #s.
    Quote Originally Posted by FMode View Post
    Where is my posting ???
    okay again:
    Ask the Silabs developers if they can move the vendor and product id from "hardcoded constant" to a file/registry (which is loaded at startup).
    Get their work and change Vendor to 0x06e1 and Product ID to 0xa155 and start...
    I can also have a quick look at the sources (VB6 and .NET only) if I got them...
    I have a HQCT, Silabs and a ADSTech...
    (sorry for no more help but HQCT is first)
  2. #42
    Mar 2005
    Wiesbaden/Germany
    Quote Originally Posted by mrWRX View Post
    The ADS-noobs wrote their own firm-crap (People always seem to have enough money and time!) for this µC.
    So what to do:
    A comparison of the circuit should show that it is nearly the same (the circuit of the Silabs is accessible I think - I should have it on drive).
    The µC, the Silabs4701 and the 3. chip is definitvely the same (and there are no more IC's on the PCB!)
    (after comparison+additional checks!!!
    I would try to flash the Silabs firmware (also accessible) into the ADSTech
  3. #43
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Has anyone made any progress on this?
  4. #44
    Feb 2006
    So the ADS and Silicon Labs units are usb direct to 'sound card' digital. But does anyone make a similar unit that uses audio line-level output? And by similar I mean a) that works with radiator, RR and similar programs and b) is in the 'dongle' form factor; powered by the USB port?
  5. #45
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    No use w/ radiator yet?
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
  6. #46
    Constant Bitrate GuMiSZu's Avatar
    Nov 2006
    Hungary
    Hi!
    This device is working good?
    RDS support ?
    If yes I'll buy it. because is cheaper than HQCT
    thx.
  7. #47
    Jan 2007
    I have it, and the adapter to hook it up to my cars antenna and it seems to work well. I get RDS on some of the stations, but the problem is it is not supported by any other applications other then what it came with... and poeple have seem to have lost intrest in it. I use it with some AutoIT scripts, and it seems to work OK for me
  8. #48
    Nov 2006
    Hungary
    Hello
    Could you send me your AutoIT scripts / tool for this device?
    thanks in advance
  9. #49
    Low Bitrate RickS's Avatar
    Nov 2005
    Bethesda, MD
    I'd like to make it work but I had trouble with their software and their SDK is all in C++ which I can't work with so it fell to the bottom of the to do list. I'd like to check out your autoit scripts too.
  10. #50
    Aug 2005
    Little Elm, Texas
    Same here... I'm surprised its not supported in RR. The low cost and RDS make it a gem too bad no one has time for it.
    Setup:
    Dynaudio 240GT
    Zapco DSP6
    ADS DAC
  1. Holux GM-213 USB GPS Receiver, Good?
    By girbot in forum GPS
    Last Post: 04-23-2006, 11:35 PM
  2. Replies: 8
    Last Post: 02-13-2006, 01:27 PM
  3. FM Radio through USB
    By JohnChimpo in forum General Hardware Discussion
    Last Post: 11-09-2004, 01:54 PM
  4. FM radio card.... (USB?)
    By chuckctv in forum FrodoPlayer
    Last Post: 10-25-2004, 08:15 AM
  5. USB FM solution good or crap?
    By Jake in forum General Hardware Discussion
    Last Post: 10-03-2002, 01:56 PM
